Need some camber shims for c5.
Old 01-21-2015, 03:18 PM
froggy47
froggy47's Avatar
Default Need some camber shims for c5.
I googled around but it's hard to tell if they will fit flat. Most don't give dimensions. The ones that came with the Pfadt camber kit were perfect.
Need to have a little tab at the top & narrow slot to hug the studs without there being too much space.
Need a kit with variety of sizes from .05mm up to .4mm probably.
What do you use?
Old 01-21-2015, 03:40 PM
ErnieN85
ErnieN85's Avatar
What do you use?
probably you could get them at an alignment shop.
I'm using the ones from Pfadt. haven't needed more
Old 01-21-2015, 03:50 PM
0JDP Motorsports
Former Vendor
JDP Motorsports's Avatar
St. Jude Donor '12
What do you use?
I have a good amount of the Pfadt shims here. Let me know what you need and we can get you taken care of on those.
Kind regards,
Jordan Priestley
888.308.6007
Old 01-21-2015, 04:34 PM
hklvette
hklvette's Avatar
You can also get them from McMaster. They're commonly used to shim electric motors to get proper shaft alignment.
Old 01-21-2015, 07:07 PM
geerookie
geerookie's Avatar
Old 01-21-2015, 07:24 PM
Last C5
Last C5's Avatar
McMaster-Carr 18-8 Stainless Size AA shims 1 1/2" X 1 1/2" with a 7/16" slot width and tab. Available from 0.001 to 0.500" thick.
CAMBER SHIM CONVERSION CHART
1 mm Shim = 00.2 degrees of camber
Shim Thickness in Inches/ Shim Thickness in Milimeters/ Degrees of Camber
0.005/ 0.125/ 0.025
0.010/ 0.250/ 0.050
0.020/ 0.500/ 0.100
0.050/ 1.300/ 0.260
0.075/ 1.900/ 0.380
0.100/ 2.500/ 0.500
0.125/ 3.175/ 0.635
0.250/ 6.350/ 1.270
Old 01-21-2015, 11:02 PM
froggy47
froggy47's Avatar
Kind regards,
Jordan Priestley
888.308.6007
Thanks! Will call if I don't get some locally.
Old 01-22-2015, 02:04 PM
el es tu
el es tu's Avatar
http://www.mcmaster.com/#standard-shims/=vkvy8o
Old 01-22-2015, 07:23 PM
froggy47
froggy47's Avatar
Originally Posted by el es tu
Thanks, exactly the ones!
The McMaster ones (AA size) are actually a little bigger overall dimension than the Pfadt ones. Maybe if you use the Pfadt first (to clear an overlap metal joint on the frame) then add the AA's they will work. I guess I'll order some & try it. The Pfadt's are 1 1/4 x 1 1/4 so a little smaller & have not found any by googling.
Thanks all.
I just eyeballed the upper shim area looking thru my wheel & they may fit. There is a "carve out" on the Pfadt dog bone that they have to nestle into so not sure there, but grinding on the shim to fit should work.
To Need some camber shims for c5.
Quick Reply: Need some camber shims for c5.
