best heat resistant wire separators in this style...
Old 02-08-2015, 10:23 AM
rithsleeper
rithsleeper's Avatar
Default best heat resistant wire separators in this style...
Well I bought these from summit http://www.summitracing.com/parts/spe-4631 and their design is very clean and simple. However after 3 minutes at idle the 2 wire separator melted from my header primary. That was with the hood up and idle, so much for when I get on the track.....
Anyone know of any with the same design like the bolt in sets of 2,3,4? I would rather not spend $50 on them since I need 2 sets because I need 4 sets of the "2" separators. Here is a pic of how I have them set up.
Old 02-10-2015, 06:45 AM
rithsleeper
Bump
Old 02-10-2015, 09:08 AM
AzMotorhead
Support Corvetteforum!
AzMotorhead's Avatar
At 5.99 a set I would think you could buy a few sets.
Or contact Spectre and see if they will sell you a "custom " set
http://www.spectreperformance.com/se...aspx?prod=4631
Old 02-10-2015, 02:39 PM
victorf
victorf's Avatar
Either make friend or pay for a Machinist/Toolmaker to make a set out of heat resistant G10 material.
Good enough will not be cheap!
Old 02-10-2015, 09:40 PM
71corv
71corv's Avatar
St. Jude Donor '08
Look for Taylor cable looms on the Summit site. Used these when we placed a period correct big block in the 67 Camaro. Haven't noticed any problems from header heat.
Gene
Old 02-10-2015, 09:50 PM
rithsleeper
I was looking at the Taylor ones and they are a bit expensive bit I will go with those if I don't find an alternative. I would have to buy two sets.
However I did see aluminum separators.... Wouldn't that defeat the reason for separators? I would think they would encourage cross firing. Or would the insulation on the charged wire along with the insulation on the potential crossfire wire would be plenty to make them a good alternative. They definitely wouldn't melt... But they might hold heat and end up melting the wire? Like these?http://m.summitracing.com/parts/dui-9002?seid=srese1&gclid=CMua-ITy2MMCFcnm7AodZloACA
Old 02-11-2015, 02:53 PM
chetly
chetly's Avatar
MadeforU if they are still in business is what your looking for. They double as valve cover bolts, come in lay down or vertical mount center bolt as well. Black, red, blue, yellow, purple, green colors just to name a few.
Old 02-11-2015, 02:57 PM
chetly
chetly's Avatar
Madeforyou part # 5075611$36 is what your looking for. They double as valve cover bolts, come in lay down. You also have the option of vertical wires. Black, red, blue, yellow, purple, green colors just to name a few.
Old 02-12-2015, 04:50 PM
fcarga
fcarga's Avatar
Here is site https://www.made4uproducts.com/cart/...hp?prod=50-756
Old 02-12-2015, 09:12 PM
71corv
71corv's Avatar
St. Jude Donor '08
Need to retract my above post. I used the "Madeforyou" parts as mentioned in the Post above. Pic on their web site looks similar to the way the wires are run on the Camaro.
Gene
Old 02-13-2015, 09:29 AM
Han Solo
Han Solo's Avatar
Looks like you could eliminate the two wire separators closest to the headers.
To best heat resistant wire separators in this style...
Quick Reply: best heat resistant wire separators in this style...
