Wiring drm diff cooler
Old 02-27-2015, 10:46 PM
huskerhank
huskerhank's Avatar
Default Wiring drm diff cooler
So I am installing a DRM differential cooler and I was wondering where do you run the wires from the pump to get up to the battery? I am installing on the driver's side as I already had a tranny cooler on the passenger side. I know once I get it up front to take it thru the firewall above the fuses to get to the battery. Thanks in advance.
Old 03-01-2015, 10:11 PM
Last C5
Last C5's Avatar
I stuck my wires inside some corregated protection tubing and ran the whole mess up front through the rocker panel. Lots of room and it comes out near the battery when you're doing the passenger side and just under the brake booster when you're doing the driver's side.
Quick Reply: Wiring drm diff cooler
