Checking The Rear Diff
Agree with Ernie and Froggy. When in neutral, your rear wheels should spin freely, even if one is on the ground. I just tested mine (was swapping out wheels for track event next weekend). I also called an engineer at a local on site track support shop that I do regular business with just to make sure nothing was wrong with my car. He said free spin is what you want to see when in neutral. Similar to Froggy, my diff clutch starts to slip around 130 ft lb when in gear.
I'm not a professional mechanic Stickshift. However, I think it is normal to be able to spin one wheel while the car is in neutral and have the other wheel do nothing (I know mine does the same). Before spending any money, I would consult with a pro.
I want to do this test. I been writing up something for a while here but it got way to technical and long.
This test really should be done in neutral with 1 wheel on the ground and a torque applied to the other axle nut.
Does anyone know if the diff is 1 way 1.5way or 2 way? It would matter for testing relative to which way you spin stuff if its not 2 way.
It must be in the service manual, although I can't find it in the electronic version I have. I did find this Dana manual with the procedure which does say to put the car in neutral.
http://www2.dana.com/pdf/5315-3.pdf
Link to a good video explaining LSDs.
Given this, it sure looks to me like the wheel is made to freely spin when in neutral. Engagement of the gear is required to bind the two half shafts together, which is what creates the equivalent of a solid differential until enough torque is applied to one wheel vs the other, which then breaks the clutch free. It looks like the motor would not move when the clutch slips, as the clutch is between the half shaft and the drive shaft (i.e., the slipping is what keeps the engine and the other wheel from turning while the one wheel with the torque being applied does turn.
Found this, post # 7
https://www.corvetteforum.com/forums...the-fluid.html
And this;
https://www.corvetteforum.com/forums...l-is-shot.html
And this;
Some of you guys are getting confused with how a limited slip diff works vs none limited diff when BOTH WHEELS ARE OFF THE GROUND.
We are NOT talking about that here. It has no bearing on testing the clutches torque.
Stay tuned.
(but maybe this is the cheaper type of diff that wears out quickly like in some (all) of the older f-bodies??)
I'm thinking this is why we see wildly varying TQ values for our cars. Some checking in neutral, some in gear. Just like Xian, my cars both show a fairly high TQ value in neutral. Although my C5 only shows around 70 ft-lbs, but my C6 shows 100+. Both checks were done in neutral. I know my C5 shows a much higher value in gear (because I've accidentally started to check it in gear before), but I've never tried to get an accurate number in that case.
Proof
Here ya go:
As to my "high" reading, I use Redline. If YOU are using the stock fluid with the slip additive, maybe that's why your break away torque is different. The whole POINT of the additive is to change the torque on the clutch break away.
So if you don't know who changed your fluid last or how much or little slip additive they used, well .........
YMMV
BTW, no, I did not inadvertently loosen the axle nut, It's on at about 165 lbs & my gut tells me that my wrench, when set to 150 lbs is probably closer to 125-135 give/take. Torque wrenches, in general, are not "that" accurate at the extremes of their settings.
YMMV
I just checked mine. In neutral, it takes about 75-80 lbs. to break loose. Just for kicks, I did both the passenger side and drivers side with same results. GM diff. oil with one bottle additive. My axle nuts were loose though.
#35
I did try it in gear and I didn't want to bust my gut trying to move it. It was like yours in gear.
#36
Just checked mine. 02 ZO6 fresh rebuilt diff with carbon fiber clutch packs and DTE hd belleville washers.
One wheel on ground, tranny in neutral: breaks at 130 ft lbs.
Tranny in third gear: 240 ft lbs. no movement. (maxed out torque wrench)
Parking brake off.
Parking brake off.
#37
I apologize in advance for this question, but, all you guys do have the parking brake full off, right? No fair testing the break away of the parking brake. I know it's a habit for some guys to pull it on.
#40
