AIM MXG DATA LOGGER DASHES/AiM SOLO II DL
Old 08-04-2015, 08:18 AM
0Xplosive Performance
Former Vendor
Xplosive Performance's Avatar
St. Jude Donor '13
Default AIM MXG DATA LOGGER DASHES/AiM SOLO II DL
AiM MXS Dash Logger
The AiM MXS dash logger contains all of exciting features of AIM's latest MXG system, but in an ultra compact 5" display. The full-color, high-contrast, TFT LCD display features fully customizable pages, allowing the user to choose from a vast library of page styles, and define exactly which data to be shown. Moving through the pages is easy through the push button selectors on the side of the dash. 8 alarm LED's are also user configurable with custom colors, flashes and accompanying messages, as is the advanced multicolor shift light.
Like many AIM systems, the MXS dash is infinitely expandable using the built-in CAN bus. Easily integrate accessories such as a SmartyCam camera system, or Lambda controller. Configuration is easy through the included Race Studio 3 software from AiM, and the dash can easily be accessed through the integrated WiFi connection.
Included:
• MXS
• 37-pin standard harness
• GPS05 Module
• USB Cable
• Software CD w/ Race Studio 3
ECU Connection: Capable of acquiring data directly from the vehicle's ECU.
• Analog & Digital Inputs: 8 Analog inputs record up to 1000x per second each. 6 Digital inputs are also included.
• GPS Module: AiM's powerful GPS05 module is included in the kit for accurate lap-time and track position data
• Secondary CAN-line: CAN2 line manages data from additional modules, such as ABS, traction-control, etc.
• Internal Accelerometer & Gyro: Internal 3-Axial accelerometer and a gyroscope for crucial vehicle motion data.
• Math Channels: Configure the dash to immediately display Math Channel values, such as brake bias or a calculated gear.
http://www.xplosiveperformance.com/A...er_p_3809.html
$2299.00 Delivered Lower US
AIM MXG DASH DATA LOGGER 7" SCREEN
The AiM MXG dash logger showcases the future of in-car logger systems! The full-color, high-contrast, extra-wide 7" TFT LCD display features fully customizable pages, allowing the user to choose from a vast library of page styles, and define exactly which data to be shown. Moving through the pages is easy through the push button selectors on the side of the dash. 8 alarm LED's are also user configurable with custom colors, flashes and accompanying messages, as is the advanced multicolor shift light.
Like many AIM systems, the MXG dash is limitlessly expandable using the built-in CAN bus. Easily integrate accessories such as a SmartyCam camera system, or Lambda controller. Configuration is easy through the included Race Studio 3 software from AiM, and the dash can easily be accessed through the integrated WiFi connection.
Included:
• MXG
• GPS05 Module
• USB Cable
http://www.xplosiveperformance.com/A...en_p_3810.html
$2600.00 Delivered Lower US
SOLO DL, WITH THE INCLUDED OBDII CONNECTER
The Solo DL is a more advanced data logging model. The Solo DL will connect to over 300 supported ECU models, including OEM CAN, OBDII, and the most advanced third party ECU's in motorsports. Thus giving you a Solo with all the above features, plus the ability to record up to 100 additional channels coming from your ECU (model pending). The Solo DL will also seamlessly interface with our popular SmartyCam video recording with real-time data overlay.
Similar to the AIM Solo, the Solo DL is an automatic lap timer based on GPS technology. The Solo locates its GPS position, identifies the track from the internal list of the main world tracks and starts automatically sampling lap times. In addition, the Solo DL, with the included OBDII connecter, logs all data coming from the ECU. Real-time GPS data (laptimes, speed, accelerations) and RPM's, throttle, water temp., oil pressure, etc. are displayed at once! (Note: OBDII connectivity and data availability may vary based on make/model of vehicle.)
The AIM SOLO automatically records and displays crucial data to improve any type of race performance: speed, performance and regularity on both open and closed circuits (ex. rally). The AIM Solo can show: speed, lap and split times, predictive lap time, best lap, and acceleration. When the race is over, all of the data can be downloaded to a PC and analyzed in the included Race Studio 2 software using graphs, tables and also real GPS images. Plus, thanks to the built-in track database it is no longer necessary to assign GPS coordinates to sample lap times: just switch Solo on and it detects the coordinates using the GPS, automatically recognizing track, lap and split coordinates.
• Integrated track database
• Accelerometer: tri-axial +/- 6G
• Size: 98x78x30
• Weight: 220g, battery included
• Display resolution: 128x64
• Waterproof
• Rechargeable lithium battery
• Battery duration: Up to 4 hours with back light, up to 6 hours without backlight
• External power: 12 Volt
• Magnetic base
• Memory: 16 MB
• Usage temperatures: -20°C/+60°C
Kit Includes:
• USB cable
• Mounting Bracket
• Wall charger adapter
• OBDII ECU harness
• Race Studio 2 Software
http://www.xplosiveperformance.com/-...er_p_3677.html
$699.00 Delivered Lower US
Old 08-06-2015, 08:40 AM
Former Vendor
St. Jude Donor '13
Old 08-10-2015, 09:23 AM
Former Vendor
St. Jude Donor '13
Old 08-12-2015, 08:12 AM
Former Vendor
St. Jude Donor '13
Old 08-14-2015, 07:49 AM
Former Vendor
St. Jude Donor '13
Old 08-18-2015, 07:36 AM
Former Vendor
St. Jude Donor '13
Old 08-21-2015, 07:54 AM
Former Vendor
St. Jude Donor '13
Old 08-25-2015, 07:56 AM
Former Vendor
St. Jude Donor '13
Old 08-28-2015, 09:28 AM
Former Vendor
St. Jude Donor '13
Old 09-01-2015, 08:43 AM
Former Vendor
St. Jude Donor '13
AiM MXS Dash Logger
Included:
• MXS
• GPS05 Module
• USB Cable
Included:
• MXG
• GPS05 Module
• USB Cable
• Size: 98x78x30
• Waterproof
• Magnetic base
• Memory: 16 MB
Kit Includes:
• USB cable
• Mounting Bracket
• OBDII ECU harness
Old 09-03-2015, 07:54 AM
Former Vendor
St. Jude Donor '13
AiM MXS Dash Logger
Old 09-09-2015, 07:57 AM
Former Vendor
St. Jude Donor '13
Old 09-11-2015, 08:45 AM
Former Vendor
St. Jude Donor '13
To AIM MXG DATA LOGGER DASHES/AiM SOLO II DL
Quick Reply: AIM MXG DATA LOGGER DASHES/AiM SOLO II DL
