o2 Sensors Burning Up - LS7 C6 Z06
Anyone else running headers on C6 Z06 having to replace front o2 sensors regularly?
They keep burning up their heater circuits after a few track days and then throw a CEL. They last forever on the street but I'm thinking it is the heat that is killing them with the headers when road racing.
I talked to my local shop and they said it is common and they replace them regularly on their track cars and customers track cars but haven't found a fix to prevent it.
Anyone found a fix to prevent the heater circuits from going bad?
OP, are you using pump fuel? Any RTV silicone or anti-seize used upstream of the O2 that might not be sensor safe? I don't have a C6 Z06 but I've never heard of this problem. It makes me think that something unique to your car is causing the issue.
You don't really want to relocate the primary O2 sensors further downstream, as this would increase the transport delay of the feedback loop. This will affect closed loop fueling, which shouldn't be a big deal for a track car, but could be on the street.
I'd check for that first as it would eventually cause other problems (exhaust valves, burned pistons)
That's true. You could also check ignition timing, as very advanced or very retarded ignition timing can cause very high EGTs as well.
It seems to only be an issue with C6 Z06 LS7 cars running headers and is happening to other cars in addition to mine. There are some other forum posts on this as well but not really much of a resolution. I see the guys from LG had these issues and they also mentioned moving moving the o2 farther back as well...I was hoping there may be another option besides this.
Ignition timing, mixture, and tune have all been checked a couple times and are spot on to where they should be.
When a vendor buys a bad batch of parts, exchanging a defective part for another defective part will lead to a problem that you have. GM has had severe quality control issues. Not sure if it has to do with bankruptcy and giving all their vendors the shaft or not. Is there a non-GM sensor you could get?
Try another brand.
