Apr front splitter on c5 cause hearing problems?
I'm finishing up my track build as of right now, and my last piece to the puzzle for now is my apr front splitter. I was just wondering if anybody on here has this splitter installed? And if so, does it effect the cooling and operating temperature? I have a heat extractor hood, 160 degree thermostat, and have my fans programmed to turn on earlier. So I don't think it should be an issue but just want to see what other people experienced. May look into the Doug rippie engine oil cooler if I need it, after I test this setup on my next track day at Laguna. Thanks!
Pretty sure you mean "heating" problems. Anyway, which splitter? Is it just the little one that does on the lip, or does it go underneath the car and cover up the bottom breathing nature of the car? If it's just the lip you'll probably be fine.
