Chassis mounting C6Z APR wing
Old 06-10-2016, 05:35 PM
  #41
c5racr1
c5racr1's Avatar
If I had a flat bottom car I would be scared
Old 06-10-2016, 06:40 PM
  #42
Racingswh
Racingswh's Avatar
Received 1,074 Likes on 644 Posts
Originally Posted by c5racr1
I won't be able to actually see it like this until two weeks at NJMP Lightning. My Wife will be at the wheel and her speeds will be 135-145 mph on the straight where I will be able to get a good look and take some photos. Your photo has me curious. If it does exhibit that dramatic a rearward lean the beauty of the Penske's is I can just add spring rate and get the shocks revalved for cheap. For some reason I do not think it does to that degree.
In that photo from Pocono I am hard on the gas in 3rd. You can see the C7Z lifting it's nose in the back ground is as well. My Wife's car just goes with a bit of power oversteer off the corner.
Her Corvette is the easiest car to drive quickly I have ever been in so far. It doesn't really push except in the very high speed stuff which leads me to believe it's not as balanced as it could be. I will do a real splitter setup over the Winter. Leaving it like it is for this season.
Old 06-27-2016, 11:16 AM
  #43
Racingswh
Racingswh's Avatar
We got tons of pics over the weekend and no squat like that at all.
Here are both cars. I am shotgun in the Viper with my Brother in Law at the wheel. My Wife in her car right behind us.
Old 06-28-2016, 12:12 AM
  #44
c5racr1
c5racr1's Avatar
What suspension is the yellow car running? What is the highest speed you have gotten it up to?
Old 06-28-2016, 06:25 AM
  #45
Racingswh
Racingswh's Avatar
Penske coil overs. 650 lb springs. 155 mph on data.
Old 06-28-2016, 04:44 PM
  #46
c5racr1
c5racr1's Avatar
Well that explains it. I have t1 springs and shocks
Old 07-14-2016, 10:00 PM
  #47
c5racr1
c5racr1's Avatar
Now going too coilovers 700lbs and adjust from there
Old 06-28-2017, 09:45 AM
  #48
LG Motorsports
Premium Supporting Vendor
LG Motorsports's Avatar
St. Jude Vendor Donor '03-'04-'05-'06-'07-'08-'09-'10-'11
LG Motorsports has everything anyone will need for a track car. Race proven and more.
Give us a call
Lou Gigliotti
LG Motorsports
972-679-8907
Quick Reply: Chassis mounting C6Z APR wing
