Corner balance with leaf spring?
Also remember to set tire pressures, disconnect the shocks and sway bars. Set the springs then bars, then shocks.
Mark.
Mark.
You use those same adjusters to effect corner change just like you would set ride height on a coil car and then fine tune the corner weight by changing the same spring perches. The rule is just like with coils you don't make your entire scaling from 1 corner or you mess up the ride height instead of spliting the difference between corners.
I like the endless loop analogy. This is never easy.
Here's an article i wrote about all of this. I think Anthony has it up on their site as well.
Richard Newton
Richard Newton
