Jacking a car in a dirt paddock
Location: Boston, Dallas, Detroit, SoCal, back to Boston MA
Yes, best advice is not to, but sometimes you don't have a choice
Not wanting the jack to dig in and the car fall off,
what's the best advice?
Carry a chunk of plywood? Which is rather cumbersome
Thanks in advance.
Thanks in advance.
Received 8,930 Likes
I wouldn't go smaller than a 3/4 inch thick piece. If you are using a floor jack you could use two pieces. One for the rear wheels and the other for the front. That would make it easier to pack. Probably would want something about 8 inches by 8 inches.
Bill
Bill
BrianCunningham (05-10-2016)
I carry a few squares of plywood anyway for jack stands on paved paddock so they don't dig into hot asphalt. Part of my travel kit. I'd cut a few and throw them in a box.
What you need depends on the hardness of the ground. For harder dirt, you need less wood width, length and thickness.
Just as a safety precaution, plywood or 2x4's under the jack should do the job for any surface other than concrete. The flat plywood spreads the load on soft surfaces like dirt or asphalt while the 2x4 seems to work best on gravel. Same procedure for jack stands too.
Hope this helps!
Hope this helps!
The following 5 users liked this post by klodkrawler05:
Bill Dearborn (05-12-2016),
BrianCunningham (05-10-2016),
Captain Buddha (05-10-2016),
Ludedude (05-15-2016),
Paul Schmidt (05-10-2016)
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Probably are not going to have to have room to bring it with you, but soemtimes we got stuck in the grass at Mid-Ohio, Lime Rock, or Road America we brought 6 to 8 sheets of 3/4" plywood to put under the cars. We welded full plates on the bottom of each jack stand so they had a full 'skid' plate under them so they wouldn't punch through the wood. The jack worked ok but you still need to be really careful.
Still remember changing the clutch in the C6 challenge car in the grass at Mid-Ohio....nightmare.
The following 2 users liked this post by Anthony @ LGMotorsports:
