LG G1 sway bars vs GM T1 sway bars
Old 12-18-2016, 02:26 PM
wjnjr
wjnjr's Avatar
Default LG G1 sway bars vs GM T1 sway bars
Same thing? Any difference in fit or performance?
Old 12-19-2016, 08:06 AM
Chad M
Chad M's Avatar
I happen to come across this anti-sway bar chart on Pfadt's web sites
tommyc6z06 (12-05-2021)
Old 12-19-2016, 10:29 AM
blkbrd69
blkbrd69's Avatar
I weighed and measured 2 sets side by side a couple of years ago.
Same bend, same weight, same diameter.
Unless they are a different alloy and heat treat???
Nice purple paint though.
Old 12-19-2016, 11:35 AM
STANG KILLA SS
STANG KILLA SS's Avatar
i thought the G1s were larger than the T1?
of course wall thickness could easily make up for that.
but if blkbird says they weighed the same, assuming the same type of steel, they should have identical rates.
Old 12-19-2016, 04:49 PM
Quickshift_C5
Quickshift_C5's Avatar
I'm running the LG G1. Decided to go with those after a lot of research between that and T1. No great reason behind the decision, everything I saw, even from LG, pointed to the fact that they were the same.
Is anyone running te Pfadt Heavy Rate sways? I'm very curious on the difference between those and T1. I avoided anything bigger than T1 spec due to how many complaints about how harsh even the T1's were on the street. All of that is nonsense, it's not harsh AT ALL. Now...I'm curious what the Pfadt bars are like.
Old 12-19-2016, 07:23 PM
blkbrd69
blkbrd69's Avatar
Might want to look at the questionable design of the Pfat bars. Yes the bar itself is stiffer but the deflection is off, and have seen many examples of broken ones.
If you are still on bushings, that is a lot of the deflection not the T1 bars.
Everything I understand the T1 is plenty stiff for real slicks, matched with proper spring rates.
Old 12-19-2016, 09:09 PM
dapopa9
dapopa9's Avatar
The RideTech MuscleBars have an interesting design to them. I have not used them but would like to hear if any one else has and also how they compare to the LG/T1 sway bars.
http://www.ridetech.com/store/c6-cor...musclebar.html
Old 12-19-2016, 09:17 PM
TrackAire
TrackAire's Avatar
The only disappointment of those bars is the price.....for $2000.00 I'd like to to see some real data regarding performance, etc.
The following 2 users liked this post by TrackAire:
ArmchairArchitect (10-23-2021), Bad_AX (12-26-2016)
Old 12-20-2016, 03:21 PM
blkbrd69
blkbrd69's Avatar
The RideTech MuscleBars have an interesting design to them. I have not used them but would like to hear if any one else has and also how they compare to the LG/T1 sway bars. http://www.ridetech.com/store/c6-cor...musclebar.html
You have got to be kidding me?
At least Phadt bars are "pretty" despite the fallacious engineering for looks vs. performance.
Ask yourself what a sway bar does?
Then ask yourself if an expensive multi-piece, multi-material bar does it better?
Does it solve or help a problem, or create numerous others?
Old 12-20-2016, 04:43 PM
C5 Hardtop
C5 Hardtop's Avatar
What they'll do is put a dent in the budget.
According to the destructions, they have two position adjustments.
Old 12-23-2016, 08:52 AM
LFZ
LFZ's Avatar
I have used on the track the Pfadt Heavy, Pfadt light, and LG G1s on a C6Z. I broke the arms on 2 sets of Pfadts, but the heavys never felt right no matter where I adjusted them. Went stiffer on the dampening and tried the Light rates...a little better, but couldn't get anything right on the track once again. Slapped on LG G1s (with G2 coils)...and WOW...this is what a track car should fee like.
Old 12-23-2016, 03:33 PM
Racingswh
Racingswh's Avatar
Received 1,074 Likes on 644 Posts
The Pfadt Heavy Rate bars were on the C6Z I bought a few years ago. They work fine and so far haven't failed. The car won a TTU Championship in 2011 and held a few track records using those bars.
If I had a problem with them I would go with the LG's and may still before there is a failure which seems over time is probably inevitable. I have seen other pfadt bar ends fail.
Old 12-26-2016, 09:01 AM
rfn026
rfn026's Avatar
Keep in mind that a sway bar is nothing more than a horizontal torsion bar.
btw - If you're breaking sway bars (not the links but the bar itself) there is a serious problem.
After checking out the price on the Ride Tech sway bar I think the Porsche bars are an absolute bargain. I never thought it possible that Corvette parts prices would exceed 911 prices. We're in a new era here.
Richard Newton
Old 12-26-2016, 09:24 AM
LFZ
LFZ's Avatar
Richard Newton
I agree....there was a serious design problem using a steel bar and aluminum bar end arms on the Pfadt design. LG had a video IIRC and explanation of how the Pfadt bars were actually acting as a secondary leaf spring (not really a torsion bar), and the design itself with the links and arm pointing straight up was not effective.
To LG G1 sway bars vs GM T1 sway bars
Quick Reply: LG G1 sway bars vs GM T1 sway bars
