Splash Shields?
Old 01-20-2007, 06:08 PM
DZVette
Support Corvetteforum!
DZVette's Avatar
Blkblt
Here are pics from under my 65. Hope this is of use.
DZ
Old 01-20-2007, 07:20 PM
Paul L
Paul L's Avatar
DZ,
Nice pics. I am sure the poster will appreciate. For some reason I do not recall that large ground cable on the passenger side. I'll have to check that in the spring.
Old 01-20-2007, 07:31 PM
DZVette
DZVette's Avatar
Hi Paul67.
Thought that might raise an eyebrow or two! Probably unique to my car. I also had one one from the left side of the block to the top of the steering box of all places. I guess the PO was into grounding! I'll pull the other one somewhere down the road. Doubt I need it. All new LL Harnesses throughout the car last year.
Best regards!
DZ
PS: I really like that green car of yours!
Old 01-20-2007, 07:36 PM
Viet Nam Vett
Viet Nam Vett's Avatar
2015 C2 of Year
St. Jude Donor '04-'05-'06-'07-'08-'09-'10, '14-'15
....News Flash.... VNV has Brain Fart..!!!!
I went into the garage to look for my splash shileds so that I could install them. After a 20 min search I found them installed on the Vette.
Forgot that I did put them on....
Old 01-20-2007, 07:49 PM
DZVette
DZVette's Avatar
Now that's funny! VNV, maybe we can meet some time. My sister lives up in North Jersey. We're about due for a trip up that way.
Sure do miss the trips to "the shore".
DZ
Old 01-20-2007, 08:00 PM
Viet Nam Vett
2015 C2 of Year
DZ
Sounds like a plan DZ.. let me know when your gonna be in the hood
Old 01-20-2007, 08:39 PM
Blkblt
Blkblt's Avatar
Blkblt
DZ
Many thanks, DZ.....
Pics say it all in these cases!!
Jeff
Old 01-20-2007, 08:40 PM
Blkblt
Blkblt's Avatar
Good to see you around again VNV!!!
Jeff
"The CCC STILL lives!"
Old 01-20-2007, 10:31 PM
JohnZ
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
Originally Posted by paul67
DZ,
If that's the battery ground cable, it goes under the head of the outboard starter attaching bolt (on a non-A/C car).
Old 01-21-2007, 04:30 AM
Paul L
Paul L's Avatar
That's where mine is. These cars have so many grounds I thought I had missed out on one. In fact I did have one missing until last summer when someone here mentioned that there was a ground cable on the accelerator rod.
Old 01-21-2007, 06:11 AM
babbah
babbah's Avatar
I need a replacment set of these sheilds. I cant find them in the LICS catalog or the AIM.
What are they called and who sells them?
Old 01-21-2007, 08:11 AM
JL66REDCPE
JL66REDCPE's Avatar
C2 of Year Finalist (stock) 2019
You have been playing around with that Hummer too long !!!!
Old 01-21-2007, 11:34 AM
  #33
JohnZ
JohnZ's Avatar
They're underbody splash shields - all the vendors have them; I'm in Florida and don't have my A.I.M., but as I recall, they're in UPC 1 Bolt/Weld somewhere.
Old 01-21-2007, 12:55 PM
  #34
1Redctoo
1Redctoo's Avatar
Default splash shields
I'm glad someone asked this question . I bought my car 4yrs ago and the shields are still setting in a box under my work bench . Ive looked around a little bit to see how they might install but have never tried to attach them. I figured they were removed to cut down on the heat build up in the engine compartment . I have had fuse box corrosion problems before but I cleaned up the box and no problems since , but I very rarely drive the car in the rain .
If anyone can post pics of them installed it would be great
Old 01-21-2007, 09:18 PM
  #35
DZVette
DZVette's Avatar
Hi John! Mine is an AC car and I have the battery ground to the bell housing (Powerglide housing) on the driver side. This one was installed by a PO. I'll yank it one of these days. Until then I guess my car is well grounded. Wish I could say that about the rest of me.
Dave Z
Old 01-22-2007, 09:04 AM
  #36
Aussie67L71
Aussie67L71's Avatar
I've often thought what these might be for and water splash shields seams a pretty good bet. Do you think that the GM boys may also have had under body stream-lining in mind also, or is this a bit of a stretch and giving them too much credit? Just a thought. Best Regards, Gary (Perth, Australia)
Old 01-22-2007, 09:06 AM
  #37
wmf62
wmf62's Avatar
St. Jude Donor '07
that's too much of a stretch....
Bill
To Splash Shields?
Old 01-22-2007, 08:46 PM
  #38
JohnZ
JohnZ's Avatar
Dave Z
Dave, that setup is correct for an A/C car, as I posted above.
Old 01-23-2007, 10:55 PM
  #39
DZVette
DZVette's Avatar
Hi John! Glad you had a safe return from FL. Believe it or not, my car also had an additional ground from the top of the steering box to the block when I got it. That one I removed when I reconfigured with a new cable from the battery to the correct location. Always an education!
Dave Z
Old 04-17-2007, 07:48 PM
  #40
mredi1
mredi1's Avatar
These are the inner splash shields. They mount to the frame in front of the firewall. The louvers are a mod and non-GM-issue designed to carry engine heat away from the firewall and under the car.
I have a 65, removed them when I put headers on, found one so far I think the other is lost. Any chance to get a set like the ones shown in your pictures ? They look qiute functional. Anything to cool my feet on a hot day in a 65 Coupe without AC. You could PM me if you know where I could get some like those. Thanks Tim
Quick Reply: Splash Shields?
