What is this carb?
Old 07-02-2008, 03:52 AM
USALT1
USALT1's Avatar
If you get an AIM, buy the index also, it will save you from just flipping through the book looking forthe section you need.
Old 07-02-2008, 03:54 AM
mechron
mechron's Avatar
looking closer at the carb pic i think that is the stamp pad at the extreme right bottom of the pic. take a pic of that pad and also the front of the head from in front of the engine. we may be able to tell the head and block.
Astrodokk
Astrodokk's Avatar
Well, there was no number on the stamp pad, which I think I found ...it's close to the front right freeze plug, right? So, crap, it may not even be a 327! I just bought a friggin souped up Bubba mobile. I'm not really a numbers guy, but I was hoping to at least have a higher horsepower 327.
Ok fellas, thanks alot for all this info. More to come later.
By the way, best place to buy the AIM and index?
Good night.
Carlos
Old 07-02-2008, 04:02 AM
USALT1
USALT1's Avatar
I got my AIM & index from Ecklers. A 350 makes more torque than a 327, and the 0010 is a good block.
The stamp pad is in front of the passenger side valve cover, you can see it from above.
Old 07-02-2008, 04:07 AM
mechron
mechron's Avatar
having a 350 is not a bad thing. you bought a car with that front spoiler, hooker side pipes?, NOM, it's not a NCRS car, but a clean fun driver hot rod, so just enjoy it. it is a clean car that needs a little detail work. there are a LOT of non-NCRS guys here. OH, by the way is a 4speed? hurst shifter? (more fun)...
Old 07-02-2008, 04:12 AM
USALT1
USALT1's Avatar
Old 07-02-2008, 04:17 AM
USALT1
USALT1's Avatar
Carlos, good luck & enjoy your '65, take it EZ, Jules
Old 07-02-2008, 04:26 AM
mechron
mechron's Avatar
Originally Posted by Astrodokk
I'll go look. I got these numbers from the left rear of the engine, driver's side close to the firewall.
2 GM 387 (or Z) 0010
I'll go check out the front of the right valve cover 6 inches down on the pass. side. Uh, do I look from above or below? Oh well, I'll try anyway.
Mechron: You wouldn't consider unretiring, would you?
the 0010 i believe is a common 350 block #, that is a casting #. not a stamp #. the 0010 block is good. you have bought a nice car from what i have seen, don't sweat the small stuff...
Old 07-02-2008, 06:43 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
Is the throttle return spring going to the radiator hose clamp ? Odd angle too - think I'd rework that.
Frank
Old 07-02-2008, 08:56 AM
mechron
mechron's Avatar
Frank
thanks=fdreano, that's what i said...
Old 07-02-2008, 09:41 AM
Frankie the Fink
Army
You did indeed !
Old 07-02-2008, 11:18 AM
Astrodokk
Astrodokk's Avatar
For the life of me I can't see any numbers stamped anywhere in front. But I thought this was interesting. The timing numbers shoe at 8 before (TDC)? I'll keep looking. The schematic is great but in my car, there's nothing in those positions.
Old 07-02-2008, 11:47 AM
  #33
Hitch
Hitch's Avatar
The stamp pad is on the opposite side of where the timing tab is just a little higher.. See USALT1's pic..
Dave
Old 07-02-2008, 12:01 PM
  #34
project63
project63's Avatar
If you found the pad and it's blank, it's probably an indicator that the engine was decked during a rebuild and the numbers were machined off. No big loss in this case being a replacement engine.
tc
Old 07-02-2008, 12:17 PM
  #35
Astrodokk
Astrodokk's Avatar
Most likely it's been decked. Here's a pic of what I think is the stamp pad slightly left of center. Sorry about the blur. Well, today I'm off to talk with car dudes. Talk with y'all later.
Old 07-02-2008, 12:18 PM
  #36
ratpack1968
ratpack1968's Avatar
You should replace that rubber fuel line and glass filter pronto.
Old 07-02-2008, 12:31 PM
  #37
mechron
mechron's Avatar
thanks=ratpack, that's what i said... .
and lose the rubber fuel line by the heater hose.
To What is this carb?
Old 07-02-2008, 01:50 PM
  #38
DZVette
Support Corvetteforum!
DZVette's Avatar
Astrdokk,
I think the stamp pad in question is circled in the pic below. Are there any letters and numbers here?
Looks like you're havin' fun now!
DZ
Old 07-02-2008, 06:44 PM
  #39
Astrodokk
Astrodokk's Avatar
No, no numbers at all, jusr flat smooth metal.
What do I replace the glass filter and rubber hoses with, metal fuel lines? New rubber? metal canister fuel filter? Suggestions?
Old 07-02-2008, 09:58 PM
  #40
ratpack1968
You can start here or try BarryK's website...
http://forums.corvetteforum.com/show....php?t=1945839
Quick Reply: What is this carb?
