Best way to plug choke tube holes in SB exhaust manifold?
An ongoing thread on exhaust manifolds mentions that some of the desirable 2.5-inch ram's horn exhaust manifolds have a hole drilled for insertion of a hot air tube used by the choke system. A bit down the road I'll change to the 2.5-inch units in my rebuilt 67 327/350. Probably I'll find a set of manifolds with the hot air tube holes.
What will be the best way to permanently plug these holes? Weld them shut?
Received 1,843 Likes
Welding is one way. Kinda' permanent though. You could tap the hole and run a set screw in it. That's functional to fill the hole.
If it were mine and I didn't want to screw up the manifolds to where they couldn't restored with the hole, I'd tap some bits of lead in the top hole, flush with the surface and call it a day. No need to plug the bottom side if you leave the internal tube in place.
Use Hot Weld metal repair paste
I tried a 38 wadcutter bullet, it melted right down the hole, much to my surprise! I had previously patched a major crack on the left side exhaust manifold with Hot Weld with great success, so I tried it on the hole using another bullet as a temporary plug to keep it in place and it worked fine. Comes in a 2 oz clear tube, looks like powdered aluminum and graphite in a solution.
Made by FAS-WELD, typically sold at independent auto store counters, handled by Great Lakes Marketing of America, 1776 E 116th St, Carmel IN 46032.
You've jogged my memory. I think JB Weld would work too, since it is rated up to 600F. Anyone happen to know if exhaust manifolds get that hot? I like the idea of a bullet as a temporary plug on the inside of the manifold to keep the sealing material in place.
The JB Weld site says to not use it on exhaust systems, so that's that. Tapping the choke tube holes and screwing in a brass plug seems the least harmful way to go. I don't want to leave the actual tube in place, because it obstructs exhaust gas flow.
Exhaust manifolds under sustained power/load will approach dull red. How hot is that? 800-900?
If you're going to remove the tube, I'd tap the holes and plug them both.
What is the need to plug the hole? It is a tube that runs through the manifold and does not have exhaust gases coming out of it. I just have mine open with nothing covering it. Maybe I'm missing something? Dave
St. Jude Donor '07
when i bought new Chinese manifolds, we drilled and tapped mine, threaded a short bolt in tightly, cut the bolt flush, and then bradded the thread/manifold interface to keep it from loosening. painted the manifold with cast iron colored manifold paint, and it was gone...
Bill
Yeah hitch, you are missing something! J/K - I have run mine without plugging for 39 years. No problems yet. I will cross my fingers.
[QUOTE=Hitch
Maybe I'm missing something? Dave[/QUOTE]
Yeah, you are. Post #6.
you're right, but the tube can burn through or fall out, causing an exhaust leak. besides, the hole looks 'ugly'..
Bill
Bill
Mine went all tyhe way through to the inside. Don't know what happened but it did.
