would you run without vacuum advance on the street?
A friend is putting a barn find hot rod 69 vette big block back together and he inherited a 70's looking mallory distributor without vacuum advance. The mallory distributor cap has the wires attached semi-permanently, it does look kind of cool in an old school racing way.
He has had the engine rebuilt (and trans, and recored radiator, etc. etc.) and is trying to figure out what to do with the ignition. My advice was to swap out the old mallory for an MSD unit with vacuum advance. But I don't have any experience with running a non vacuum advance car on the street.
What do you guys think? are there other alternatives (like adding a vacuum can to the mallory?). I wish I had a pic to post of the thing, I might be able to swing that later on if useful.
Gerry
Gerry
I don't think mating a vacuum can to a mechanical distrib is a good idea. A total swap out is probably best. Vacuum advance will give you better mileage, cooler running and basically 'comes off' when you floor it so you are pure mechanical anyway at full throttle. There is no real downside to adding it (and I did!).
DARN...Snake beat me to the punch..
Received 6,530 Likes
C2 of Year Finalist (track prepared) 2019
The advice so far is good: If you've got the option of having vacuum advance connected, by all means do so.
However, not having it isn't fatal.
Many Vettes left the factory without provisions for vacuum advance and they run just fine. My FI '60 is a great example; it runs well and is pleasant to drive.
In the case of the subject car, I'd try it and see what happens. You can always find a way to install a distributor with a vacuum can if need be.
Jim
Jim
for 4 years with no problems.
That was waaay before I was converted to the church of the bow tie.
You need vacuum advance for part throttle, light load conditions. Sure it will run, but conditions will be far from optimum. In many cases you could be up to 10 or 15 degrees retarded from optimum.
Advance that is fixed based on engine speed alone is for high load applications, like race cars and airplanes.
Harry
Harry
Jim
You don't have to have vacuum advance and I ran my car like that for many years. To be honest I liked it that way with no ill problems. It wouldn't get hot in traffic, it wouldn't detonate, it wasn't any less fuel efficient. Lots of people will tell you that you have to have vac advance for the engine to be happy on the street.. Sorry but you can run it with no problems.
calm down now jim......i dont think we want another vac vs. non thread to start.....you better go grab the shot glass and relax a bit.....
JIm
I run a couple of built big blocks with no vacuum advance. I run a tight advance curve in them and more timing from a vacuum advance would cause them to ping under light load.
Vacuum advance does nothing for heavy throttle running, and I am more interested in having the cars run strongest under full throttle. A vacuum advance that can be adjusted could possibly work, but I am not worried about light throttle operation or fuel mileage.
square on all 4 corners, believe it gentlemen, ....regardless of what your told...thats the way it was. Dual points and no VC can.
No better gas mileage, no better part throttle response, no better low speed drivability?
Damn, you shoulda been Grand Poobah of the automobile engineering world!
Doug
Are you telling me that GM and Ford and Chrysler wasted hundreds of millions of dollars putting on vacuum advance cans that served no purpose?
Doug
Doug
And I thank you for the Grand whatever thing. Many bestows but that ones a first.......
have some on me, ......I make great popcorn too
As you can tell this is a 50/50 split. Me, full MSD ign. with mechanical advance. Played with my curve and initial advance by seat of the pants and it's very peppy at any point of the rpm range. Runs very cool just idling too, but then again I am a long way from OEM with my 350 on all set-ups. I'm not the most gifted mechanically so I have sought advise to a few mechanics/builders and I have found each has their own preference that works and the end result is the same but getting there is different.
Not saying that's not what you experienced, but with the later model 340 Dist, not necessarily true due to a much better advance curve. For many years the 340 Dist was the performance distributor of choice.
