1964 convert rear wheel squeak
I've started to notice a squeak coming out of my rear driver's side wheel/axle area. It's a rhythmic sound when I'm driving the first mile or so, then it goes away.
If I push in on clutch (take power off the train), it stops until I let out the clutch again. It's hard to diagnose, since I'm driving at the time.
To eliminate the tire and wheel possibility, I rotated the wheels - sound still coming from driver's rear. That leaves the rear wheel bearing or u-joints.
I'm thinking of buying new U-joints and replacing to see if it is there.
But does anyone have any ideas how to diagnose first without replacing U-joints?
Received 1,843 Likes
If the wheel goes in/out more than a little (how much is that?) or you hear a grinding noise when you spin the wheel, you've likely found your problem.
If you don't find anything in the half shafts or bearings, go to the driveshaft next and check those u-joints.
Received 2,127 Likes
Look at each U-joint first before you take them apart. If you see reddish brown dust around them, you NEED u-joints, as this is a sign of them being dry and rusting. Dennis
PS, check you lug nuts. Don't ask me how I know about this, 'cause it's embarrising. Dennis
OK, before I'm reading the shop manual to pull the half shaft out. I haven't done this before, but this is what it looks like I have to do.
Disconnect the inboard u-brackets from that u-joint and then unbolt the outboard u-joint and slip the shaft inboard off the splines of the spindle.
Apparently there is a cotter pin, spindle nut and washer that I need to remove after I pull out the half shaft - I can't see them right now. Then I can pull out the spindle, check it and grease/replace as req'd. I'll also check both sets of u-joints as mentioned above.
Is that it?
Reason I'm asking is that the manual discusses marking camber cam and bolt in relation to bracket. I'm not sure why I need to do that.
Is that it?
Received 1,857 Likes
Is that it?
Is that it?
Unless you've done all of this before and have all of the special tools required, you DON'T want to remove the spindle nut and try to remove the spindle; you'll be way over your head - leave that to a shop with the tools and expertise to do it right.
So, if I wanted to pack and grease the spidle bearing surfaces, I should have someone with the tools do it? Or is there a grease fitting somewhere I can access?
My rear driver's side squeak turned out to be the wheel bearing. If they've never been repacked, you've got 46 year old grease in there. Don't drive it much until you're certain because you can wreck the spindle if the bearings fail completely.
