62 AFB jetting for 300 hp/340
Old 06-03-2010, 07:53 PM
tach drive 61
tach drive 61's Avatar
Default 62 AFB jetting for 300 hp/340
where the AFB`s 3269s carb`s jetted the same , for 300 HP and 340HP 327 motors i have just built a stock bore 327 and am running 291 double hump heads and a 151 447/447 L 79 cam . my main question is would this very stock AFB carb lean out with the camshaft combination ? I will be using the steel 300 hp intake .
Old 06-03-2010, 07:59 PM
62Jeff
Support Corvetteforum!
62Jeff's Avatar
This thread may help, although it doesn't directly answer your questions
http://forums.corvetteforum.com/c1-a...jet-sizes.html
After I finish eating, I'll check the ST-12 to see if the carb was the same for the 2 engine ratings. I wasn't thinking the 300 horse used the 3269S.
Old 06-03-2010, 08:05 PM
tach drive 61
thanks jeff ,I ran the carb on a 350 with a 0.60 bore and the carb used to lean out , before i send it to bob kunz , home work helps ! I currently have the edelbrock 600 cfm and performer intake , has to go !
Old 06-03-2010, 08:12 PM
62Jeff
62Jeff's Avatar
My ST-12 shop manual shows only one set of metering rod/jet numbers for the 3269S, and it appears at first blush that the carb was used on the 300 horse as well as the 340.
ST-12 lists stock metering rods as .069" x .060"
Stock primary jets as .104"
Stock secondary jets as .068"
But of course see my other thread for a reference to updates (which aren't specified) to those dimensions later in 62.
Old 06-03-2010, 08:15 PM
tach drive 61
My ST-12 shop manual shows only one set of metering rod/jet numbers for the 3269S, and it appears at first blush that the carb was used on the 300 horse as well as the 340. Still checking some data on that part though.
But of course see my other thread for a reference to updates to those dimensions later in 62.
thankyou , the 340 HP cam specs should be close to l 79 lift , should work then !
To 62 AFB jetting for 300 hp/340
Quick Reply: 62 AFB jetting for 300 hp/340
