rear main seal is seeping oil
Old 08-20-2010, 06:24 PM
BK N 66
BK N 66's Avatar
Default rear main seal is seeping oil
anyone else having problems with the rear main seal dripping oil?
its not a lot of oil but after the motor gets hot and i return her to the garage she drips oil? just replaced the rear main seal in a complete
motor rebuild? dont know why it would be leaking oil? but it always
seems to have oil at the bottom of the bell housing.
my friend says they all leak a little from the rear main seal because of the crank shaft wearing a groove in the end and causing it to leak
oil? does this make sense? does everyone have leaks? it is not a
lot of oil but a little puddle under the car that is enough to be really
annoying for me?? thanks
Old 08-20-2010, 06:28 PM
66jack
66jack's Avatar
One piece seal or 2 piece?
One piece pan gasket?
My 2 piece one does not leak if that helps.
Are you sure its not the pan seal?
jack
Old 08-20-2010, 06:48 PM
mhanley
mhanley's Avatar
Default Oil Leak
I think they all leak its just a matter of time.
Old 08-20-2010, 09:50 PM
MidYearRoadster
MidYearRoadster's Avatar
new one piece oil pan gasket....nice small bead of silly to boot...and the darn thing still drips. not bad but enough to bug you ...then again I am parking on my kwik lift at an angle too....but still...and i have a relatively fresh rear main in too...well at least things wont rust under there
Old 08-20-2010, 10:34 PM
Glasshole
Glasshole's Avatar
I have the same problem at the other end. Brand new rebuild and I get little drips from the timing chain cover seal where the balancer is. PITA
Old 08-20-2010, 11:36 PM
mikem350
mikem350's Avatar
FWIW, when the rear main bearing cap is installed (during a rebuild) you are supposed to add sealer between the cap and block.
This may or may not be the cause....but possible
Old 08-21-2010, 07:11 AM
BLOCKMAN
BLOCKMAN's Avatar
Rear seal leaks are a PITA!! We have always used the the red Viton rubber seals and we do use silicon on the outter edges of the seal set them in place and roll it in with my finger.
Now I have seen guys offset the seal and when setting the rear cap on it will peel the back of the seal and that always causes a leak!!
Old 08-21-2010, 07:25 AM
Mossy66
Mossy66's Avatar
St. Jude Donor '14
Just because there is oil at the bottom of the bell housing doesn't mean that it is the rear main seal. Oil could be running down from somewhere else or getting blown back.
Mine was the oil pressure line fitting
Gerry
Old 08-21-2010, 10:00 AM
66since71
66since71's Avatar
Gerry
good advice. remove starter, oil filter and then the sheet metal cover to expose the back of the flywheel. If the flywheel is not wet with oil, its not likely the rear main seal...
Harry
Old 08-21-2010, 10:55 AM
Kensmith
Support Corvetteforum!
Kensmith's Avatar
Also check the back of the intake. Sometimes it doesn't get sealed properly and will leak down the back of the motor and rear of the oil pan. Also valve covers at rear area since the motor points slightly down in the rear.
To rear main seal is seeping oil
Quick Reply: rear main seal is seeping oil
