How to dull polished aluminum
How does one dull aluminum that has been polished? I'm grinding down some welded cracks in an intake and in the process, the area has become slightly polished.
Does anyone think Eagle One Etching mag cleaner will dull the polished area back to original, or do I have to use something like muratic acid (diluted or full strength)? This is not a fullblown restoration, just want it to somewhat match.
It depends on how much you want to knock it down. I'd start slow and work my way up as it's tough to back up if you kill it too much.
Try a stiff toothbrush and scouring powder/water mixed into a paste. That will dull it slightly. If you want to go really aggressive, mix a little Drano with water and brush it on, but be prepared to rinse immediately so it does not get out of control.
Good Luck!
Good Luck!
Just spray the acid on for a while and rinse. If you want to localize, use a q-tip.
You can use a little steel wool to even it and bring it up to the level you want.
Old fashioned oven cleaner will do it too.
If the manifold has a rough or textured finish while chemicals will dull it you have to bead blast it to get a uniform finish. It just depends on how "perfect" you want it to look.
Received 6,530 Likes
C2 of Year Finalist (track prepared) 2019
I've tried oven cleaner. My observation was that it noticeably darkened aluminum and pot metal. Probably best to test in an inconspicuous location before committing to this chemical.
Jim
Edit: More accurately, I've tried the active chemical that's typically found in oven cleaner. It's available in hardware stores.
Jim
try and find a old beat up one or similar to test on first
This manifold has a crack welded and all four flange edges had 3/8 inch of aluminum weld added to cover larger head ports. You can not distinguish the added metal.
Shaped the weld deposit then lightly hit with small grain sandblaster.
The flange areas were shine until kissed them with sand blaster.
Joe
Joe
