Adjusting Clutch fan?
Old 09-12-2011, 02:38 PM
SMOKINGJOE
SMOKINGJOE's Avatar
Default Adjusting Clutch fan?
Hi all which way should I adjust the spring on the front of my clutch fan. Which way does what?
Old 09-12-2011, 04:25 PM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
Here ya go!
File Type: pdf
Old 09-12-2011, 06:38 PM
62Jeff
Support Corvetteforum!
62Jeff's Avatar
Counterclockwise to make it kick in sooner, if your fan clutch is configured to kick in at 210 currently.
http://forums.corvetteforum.com/1571472351-post7.html
If it's already adjusted to kick in early, then turning it clockwise will make it come in later.
Old 09-12-2011, 09:35 PM
SMOKINGJOE
SMOKINGJOE's Avatar
Thanks Guys I’ll check that out I hope it helps. Car just runs a little hot with the air on
I will also check the clutch might need a new one after all its 20 years old.
Joe
Frankie the Fink & 62Jeff
Old 08-04-2012, 11:42 AM
levonh
levonh's Avatar
Great tip. I just did my big block (Chevelle at the moment). It was locked full CW. 1/2 turn CCW and we'll see what happens.
Old 08-04-2012, 11:55 AM
Frankie the Fink
Army
I tried this adjustment on my '61 clutch but really didn't see much difference -- others have though..
Old 08-04-2012, 01:29 PM
levonh
levonh's Avatar
Just got back from a 1 hr drive. Temp never budged off of 170 deg.
Outside temp is 75 deg.
1 happy puppy
Old 08-04-2012, 03:32 PM
KC John
KC John's Avatar
C2 of Year Finalist (appearance mods) 2019
170º is a little on the cool side for making sure all the moisture is removed from your oil. If you have it all working properly now you can install a 180º or 195º and you'll be in business.
The thermostat only controls the bottom number, it won't let the engine get cooler than the number set on the thermostat, but has no effect on how high the temperature can go.
Old 08-04-2012, 05:04 PM
jprop
jprop's Avatar
Jeff, I've got the same clutch and am running a little warm. Did you notice any difference in the engine temp after the adjustment?
Old 08-04-2012, 05:27 PM
62Jeff
62Jeff's Avatar
No, extensive testing showed that nothing really keeps my 62 from getting up to 220 is the car is left to idle for about 30 minutes or so. The car runs at 175 at speed, but sit at a long stop light, and the temps start to climb. I suspect lots of crap in the coolant passeges of the block.
Old 08-05-2012, 12:51 AM
levonh
levonh's Avatar
180 going in on Monday.
Old 08-05-2012, 12:53 AM
levonh
levonh's Avatar
Mine would only move 180deg CCW then stop. You could move it back but it would not do complete revolutions.
To Adjusting Clutch fan?
Quick Reply: Adjusting Clutch fan?
