What do you think of this '64 fuelie?
Hi all,
I have owned a number of C3's and recently have started to look for my first midyear. I have narrowed down my search to the following parameters:
- coupe
- fuelie
- original or with minor modifications
- preferably 4 speed
- would ideally like 63 split window, but probably I could not afford split window fuelie...
So, based on the criteria above, I have found several options, that caught my eye. This is one of them:
http://www.cars-on-line.com/37485.html
May I kindly ask for some input about the price and what you see in the pictures. Ok, I do agree, that they don't show much, but I will be in contact with seller for more information. Many many thanks!
- coupe
- fuelie
Received 6,943 Likes
2015 C2 of Year Finalist
I must say black with silver interior is a great combo. Would like to see the trim tag
Daytona blue.
Not enough detail in any of the pictures to have a clue what the price should be. If you get more pictures, post them and someone here can help.
Thanks, guys! More pics are here. According to the seller, numbers match (engine pad, FI unit, etc):
http://www.scottsdalecorvettes.com/n...tte/index.html
Any red flags?
Any red flags?
Received 6,529 Likes
C2 of Year Finalist (track prepared) 2019
The pictures have insufficient resolution to permit drawing many conclusions either good or bad.
One thing I see is the choke heat tube is goofy looking.... an amateur bending job if ever there was one.
Jim
Jim
Thank you for comments, guys. Maybe this is not a politically correct question, but what do you think of the price, based on what you see in the ad?
My gut tells me that is all the money for that car if it is perfect. I know what my original 64 327/365 hp Daytona blue coupe is worth as i follow the market a bit. I do not follow the market for this particular car. Remember some think this year is the stepchild of all midyears (i don't) and many times the prices reflect that. If the car is all there, perfect, with all important pieces, solid, ect, ect, I would GUESS it would be a 65000 car max to the right person. You will get many here giving probably better advice than myself, but thought I would throw you my .2 cents!
Where is the PCV valve on the air meter? A 64 fuel unit should be a 7380 unit and have the PCV on the rear of the fuel meter. Is this a 63 fuel injection unit?
Received 1,843 Likes
Late '64 used a vacuum restrictor fitting in the front of the plenum (instead of the valve) and pulled in fresh air from the air cleaner adaptor back to the rear of the block.
Early '64's used the leftover 7375 units with a pcv dropping off the right rear of the plenum and connecting a metal tube go to the rear of the block.
Received 1,762 Likes
No way for a 64 and now knowing the f/i is not to the car and having to do something on that cant say it is one thing and really being something else. Hard people when it comes to selling a 100% org car and its not that for sure here....Plus a good 64 head unit will go for in the big $$. If all the other check out I would say 55,k to 60,k on the high side... Robert
Quote from Corvette Magazine's Market Report, "Without the cachet of the '63 or the upgraded hardware of later Sting Rays, '64s (22,229 built) are often overlooked by collectors. Forget the hype - paying lower prices for a stellar machine is good in our book."
Received 1,728 Likes
2018 C1 of Year Finalist
First, a couple of things. You need to be wary of any Corvette that is selling as an original FI car. There is too much of a financial incentive to fake these cars, so be sure to perform due diligence on this car before your write the check; otherwise, at $65K you will end up with a $40K fake with a used injection unit that may bring $7K.
The '64 bashing derives from a couple of things, imho. First, the SWC concept is more preferred and the '63 is the first year of the C2. The '64 is sandwiched between the '63/'65 and the advent of disc brakes, the first year of the 396, with the last year of a very limited number of FI cars in '65 seems to make the '64 irrelevant in the minds of some.
Personally, I think it is a distinction without much of a difference. The difference between the '63/'64 roadsters is a non starter for those who might argue otherwise. I would never pay up for a '63 vert vis a vis a '64. THE SWC is why you pay up.
By and large, I like the drum brakes on the '64 as opposed to the the discs on my '67. They work well on the street and they are very, very inexpensive to maintain.
Anecdotally, when these car were new, one of the rubs on the '64 was the poor design of the OEM hubcaps. Most people didn't like them then and they are not nearly as nice as the '63 hub, imho. Sometimes it is the cosmetic issues that turn people off. On a positive note, the FI engine for '64 was the most powerful motor that Chevrolet ever produced in 327 form.
Personally, I think it is a distinction without much of a difference. Th difference between the '63/'64 roadsters is a non starter for those who might argue otherwise. I would never pay up for a '63 vert vis a vis a '64. THE SWC is why you pay up.
http://www.ebay.co.uk/itm/Corvette-C...ht_1246wt_1062
Otherwise, I agree with you on the '64 models. The disc brakes can be more liability than an assest. I like the interior of the '63-'64 better than the later cars.
I wouldn't be too hard on this seller. He's not advertising an authentic car and his is open to offers. But, I would agree that I wouldn't pay a premium for this car based on the pictures or the advertising verbage.
