oil filled coil
Location: Kingston, TN, Denham Springs, LA & Agoura Hills CA
So were the ones that failed mounted sideways?
Whats the oil for if not for cooling? Wiring will melt/fuse if the internal coil wire gets hot enough! Worstcase, @12V and 0.32 ohms = ~35amps or >400W that could be dissipated inside the coil housing.
Has anyone cut one apart to see how they are constructed?
Pertronix took them both back no questions asked. I now use the stock coil with zero failures.
