1960 Trunk Lid Weatherstrip Problem/Question
Old 11-07-2012, 05:07 PM
C1-Curt
C1-Curt's Avatar
Default 1960 Trunk Lid Weatherstrip Problem/Question
I bought a new weatherstrip for my 1960 Trunk Lid from Corvette Central and what came is the cushy rubber weatherstrip. I installed it on the trunk lid and when I close the trunk the rubber along the edge of the hinge side (the body edge between the top boot lid and the trunk lid) gets caught up on the body unless I push it back in while I am closing the trunk. It appears I do have an aftermarket trunk lid and the molding of that might be my issue but I figured I would ask
Has anyone else come across this problem and is there maybe a different type of weatherstrip material that might not have this issue? Also would there be any downside to mounting the trunk weatherstrip seal on the body rather than the trunk lid. The only thing I could see happening is in rain the water may not flow off correctly.
I installed the deck lid (top cover boot) weatherstrip the same way and it works great.
Old 11-07-2012, 06:27 PM
AZDoug
AZDoug's Avatar
Received 1,478 Likes on 905 Posts
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Can't answer if you have a repop trunk lid or not.
Is the stuff you got molded, or the hollow tube weather strip?
I honestly can't remember what I got 4 years ago ( I bought Corvette Rubber stuff, and paid extra for deluxe molded weather strip where it was available), but I glued it up right in the corner of my '61 trunk lid(obviously diff than yours),a nd it worked perfect, can't see it from the outside, and it seals just fine with no closing issues.
I glued it with the lid off and upside down, and the seam is at the top middle.
Doug
Old 11-07-2012, 06:43 PM
C1-Curt
C1-Curt's Avatar
Doug
Mine is the hollow stuff with two equal flat sides and the rest is a rounded arch. I even tried gluing the other flat side to the inside edge to try to pull it way from the outer edge and still have the same issue. I did install mine with the trunk off and upside down, much easier
It looks like 53 to 58 had a different type of weatherstrip, wonder if that is thinner, I might have to look into that to see if that would help my situation.
This is what I have now.
Old 11-09-2012, 07:39 AM
stratplus
stratplus's Avatar
On my 60 I installed the weatherstripping from CC and it was as described. A black, firm rubber with the ribs. It had some give to it but it was not a soft cushy foamie type of rubber. The trunk closes fine with it.
The weatherstripping is suppose to go on the trunk lid as opposed to the body. I am not sure what body mounted weatherstrip would do for the water.
Old 11-09-2012, 10:02 AM
wombvette
wombvette's Avatar
I believe the original was actually an L shaped piece, but the round style has been supplied as a replacement for years even by GM.
Old 11-09-2012, 10:57 AM
firstgear
Support Corvetteforum!
firstgear's Avatar
2019 Corvette of the Year Winner
St. Jude Donor '15
Yup, been there. I took the weather stripping in that area and trimmed it. You can't see it and it fits fine now.
Old 11-09-2012, 11:24 AM
Frankie the Fink
Frankie the Fink's Avatar
Received 7,082 Likes on 4,736 Posts
Army
The repro weatherstrip is a known problem. If you look at most later C1 trunks that use it then you will see the gap where the trunk lid is latched down tight near the lock is perfect but the gap elsewhere is larger. The rubber repros are just too fat.
Old 11-09-2012, 12:34 PM
wmf62
wmf62's Avatar
St. Jude Donor '07
absolutely true,,,,, my original was L-shaped, not this D-shaped POS that is being sold as a replacement
Bill
Old 11-09-2012, 03:59 PM
AZDoug
AZDoug's Avatar
I went out and looked at mine, it is a simple hollow round tube with no ribs, (not D shaped, either) it fit fine and worked fine, though i do recall wondering about it when i installed it, as originally i had an OEM L shaped piece.
Doug
Old 11-09-2012, 04:37 PM
3310vette
3310vette's Avatar
i purchased the trunk w/s from Corvette Central to install on my 1960, removed the trunk lid and installed it with few problems (used a lot of clamps to hold it down) and had no fit problems. It requires extra effort to close it, but works just fine. I have seen original trunk w/s on a 1960 and it looks just like the repro, not L-shaped. Be sure that the two ends meet in the middle of the trunk before you cut off the excess.
To 1960 Trunk Lid Weatherstrip Problem/Question
Quick Reply: 1960 Trunk Lid Weatherstrip Problem/Question
