1966 front upper a arm bolts
Old 06-07-2013, 03:07 PM
alec cole
alec cole's Avatar
Default 1966 front upper a arm bolts
I have a 1966 that was built on nov. 16 1965 and i want to make sure i use the right bolt. I know the early c2 use a square pattern where the bolts connect. There was a change to a round pattern in 1966 but did not know the exact date. Does anyone know the month they made the change. thanks
Old 06-07-2013, 03:17 PM
DansYellow66
Support Corvetteforum!
DansYellow66's Avatar
Received 2,620 Likes on 1,952 Posts
Do you mean the studs that mount in the frame that the a-arm secures to? My Jan 66 car has the studs like wheel studs with the striations that lock them into the frame material to prevent rotation.
Old 06-07-2013, 08:16 PM
JohnZ
JohnZ's Avatar
Received 1,857 Likes on 1,100 Posts
I think he means the cross-sectional shape of the upper control arm shaft (square vs. round); the shafts were square or mixed square and round until about late December, 1965, when round shafts became typical.
Old 06-10-2013, 08:11 AM
alec cole
alec cole's Avatar
thank you john. I have round shafts on my nov. 16 1965 and it looks like someone changed the upper a arms during a previous restoration. I am doing a frame off and want to put it back together as correct as possible. thanks again alec
Old 06-10-2013, 09:34 PM
KC66
KC66's Avatar
Mine is a Nov 66 also. It has square ones
KC
Old 06-11-2013, 10:52 AM
iflyto
iflyto's Avatar
My 66 has a Dec. 27, 65 build date and both are square.
Old 06-11-2013, 05:42 PM
SkyDriver
SkyDriver's Avatar
My '66 was built Nov. 20th and has the square shafts (which are the factory originals).
To 1966 front upper a arm bolts
Quick Reply: 1966 front upper a arm bolts
