How do I removed the bonding strips
Old 07-18-2013, 10:53 PM
Dale002
Dale002's Avatar
Default How do I removed the bonding strips
Is there a way to remove the bonding strips without damaging something?
Old 07-18-2013, 11:00 PM
54greg
Support Corvetteforum!
54greg's Avatar
Old 07-18-2013, 11:15 PM
desertpilgrim
desertpilgrim's Avatar
A little more specific infomation is required, if you can provide it.
Old 07-18-2013, 11:51 PM
Dale002
Dale002's Avatar
What is the easiest way to remove any bonding strip from a 62. Sample, the bonding strip from the front fender.
Old 07-18-2013, 11:52 PM
Dale002
Dale002's Avatar
Originally Posted by 54greg
That bad?
Old 07-19-2013, 12:17 AM
65GGvert
65GGvert's Avatar
Received 3,221 Likes on 2,303 Posts
OK, I'll ask: Why would you want to remove the bonding strip?
Old 07-19-2013, 12:35 AM
MrPbody
MrPbody's Avatar
preferable to grind out a groove from the outside of the body panel first , into the bonding material (there will be about a 1/4" gap between body panels). using a stiff putty knife, tap it in between the bonding strip and body panel. they pop loose much easier than you might think, but go slowly along the length so as not to damage the body panel or bonding strip. you may want to work along the inside, in areas with access, as well.
Russ
Old 07-19-2013, 01:15 AM
Dale002
Dale002's Avatar
Russ
Thanks Russ, I Will have room from the inside. Will heat help? My 62 has a previous repair that needs to be redone. They just cover the strip with cloth and it looks like dog waste. It has also a few others that are partially un attached and I would like to remove and install them correctly. I also need to redo my nose section. it was modified many years ago to eliminate the front bumper,I have to establish the bumper recess. so those strips have to come off as well.If I'm able to remove them and reuse them it would be great.
Old 07-19-2013, 01:17 AM
Dale002
Dale002's Avatar
Usually they are removed when they are damage,incorrectly installed,partially loose or if you need them off for a repair. There may be a few other reasons.
Old 07-19-2013, 10:25 AM
5869vette
5869vette's Avatar
Yes, Dale heat will work.
Just go slow and don`t overheat.
One person heating and another using a thin putty
knife between the panel and bonding strip will
get it loose.
Good luck.
Tony
Old 07-19-2013, 10:54 AM
MrPbody
MrPbody's Avatar
Awww. so Goober did your body work also. that guy did get around didn't he.
I've never tried using heat, but then I never felt I needed to. they always came off easily for me.
If you need any measurements let me know, as I still have the bumpers and grill etc., off my 62.
Russ
Old 07-19-2013, 11:54 AM
AZDoug
AZDoug's Avatar
Received 1,478 Likes on 905 Posts
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
If the parts are off the car, a Porter Cable 10" (or 7") angle grinder with about 24 grit discs make short work of them. Kind of messy, do it outside and wear a dust mask and a disposable painters overalls.
Doug
Old 07-23-2013, 05:44 PM
zeus337
zeus337's Avatar
Cruise-In II Veteran
Cruise-In III Veteran
You don't. More value and originality on a car with visible bonding stripe. It also shows the car may not have been in an accident or had serious body work.
Old 07-23-2013, 06:42 PM
SoCalC2
SoCalC2's Avatar
Use a heatgun a chisel should work very well. That is what traditionally gets the job done with panels and replacements. May need some grinding as well, but heat is usually the best thing.
Old 07-23-2013, 11:54 PM
firstgear
firstgear's Avatar
2019 Corvette of the Year Winner
St. Jude Donor '15
get it loose.
Good luck.
Tony
I used a heat gun as well, softens up the bonding material and you can scrape it as you go. This assumes that you have clear access to put the heat gun on it and to get the scrapper in there.
Old 07-24-2013, 08:46 AM
mickatbp
mickatbp's Avatar
Good opportunity for some photos as you do it to show the rest of us what to do (or not to do)
Old 07-24-2013, 09:04 AM
Fawndeuce
Fawndeuce's Avatar
If they glassed over the strip with cloth, you'll probably have to grind everything off like Doug was saying, or you could tear up the panels trying to pull the bonding strip off, unless the cloth didn't bond well?
Paul
To How do I removed the bonding strips
Quick Reply: How do I removed the bonding strips
