1963 convert door panel help
looking to replace my door panels, but mine, which look original, have carpet from the chrome trim down, every panel i looked at only show a small strip of carpet at the bottom of the panel
any help would be appreciated!!
thank you for the reply's,, im no expert, but looking at the panels, they look like the original panel??? is it possible this was done on the early 63 converts???
thank you so much!
thank you so much!
Peel the carpet back and see what you find. I'll bet the carpet is glued over the original vinyl.
Chuck
if i need to lock the car, i use the key but i never lock it
thank you! I like that look also and just thought it was factory
