Lowerering a C2 in the rear
I just installed the 8" bolts on my '66 and lowered it 1.5". My question is since it was aligned recently, what would be a reasonable amount of adjustment to keep the rear wheels "straight" short of getting a realignment? The rear went down 1.5" and the front went up 3/8". I don't think the front going up 3/8" would be of much concern regarding front alignment, but 1.5" in the rear might be, or am I wrong?
Also the 8" bolts are not drilled for using castle nuts with cotter pins and I used nylon lock nuts. Are these safe or should the bolts be drilled and cotter pinned?
Thanks for all replies.
Received 1,857 Likes
The Nylock nuts should be OK; mark them and check them occasionally for movement.
I agree with JohnZ. Nylocks on mine have been fine.
You can eyeball the camber and adjust, but Id recommend an alignment.
If you recently had an alignment...hopefully you have the print out on the specs of when it was done. And YES...I know the settings can change due to driving...but I would have the alignment heads put back on it just to make sure your toe adjustment is not too far out of spec in the rear. 1 inch is as about as a far as I will go until I start having concerns in the rear toe adjustment when lowering the suspension. Just my thoughts on this issue.
DUB
DUB
