C2 Performance Tires
Old 04-10-2014, 09:36 PM
jamesinyork
jamesinyork's Avatar
Default C2 Performance Tires
Ok, took the car out today and ran it. Was not happy with the tires(Michelin X). What tires help w/performance. The Michelins wanted to dart around. Looking for a good handling tire. Recommendations??
Thx. Jim
Old 04-10-2014, 09:46 PM
66since71
66since71's Avatar
Lots of good tires.. I'd look for three things... Highest speed rating (=responsive sidewalls, good turn in), highest traction rating (obvious) and worst wear rating (even higher high traction).
Harry
Old 04-10-2014, 10:29 PM
project63
project63's Avatar
Sounds more like alignment issues. Or possibly a separated belt in one of the tires. How old are they?
Old 04-11-2014, 12:41 AM
Mike67nv
Mike67nv's Avatar
2018 C2 of Year Finalist
2015 C2 of the Year Finalist
Michelin X Radials are not “bad” tires. They may not be the highest rated performance tire on the market, but they are one of the better tires that come in compatible C2 sizes. Your symptoms sound like alignment or suspension component issues.
I would recommend getting a good four-wheel alignment before you throw the tires out. For street driving with radial tires, try the following alignment specs:
Front Camber: 0*
Front Caster: 2.0*-2.5* positive (with power steering), 1.5* with manual (2.5* will work but low speed steering effort will increase substantially)
Front Toe: 0 to 1/16" total toe-in
Rear Camber: 0 to 1/2* negative
Rear Toe: 1/16" total toe-in (1/32" per side, split equally across the thrust centerline)
Old 04-11-2014, 03:42 AM
Revfan
Revfan's Avatar
Thanks mike67....
Good info and I will be doing this soon!
Old 04-11-2014, 07:17 AM
jamesinyork
Default C2 Tires
Front Camber: 0*
Thanks All. I will get the alignment done first & check each individual tire. The car is new to me and my first C2, suspension was rebuilt not long before I purchased. Pretty impressed w/the car's acceleration just didn't feel right. Thanks Again for the info.. This forum is one of the best I have seen w/members sharing info.. Jim
Old 04-11-2014, 07:59 AM
ricks327
ricks327's Avatar
Received 1,613 Likes on 901 Posts
You want bad tires? Buy Cokers, then you will find out that Michelin X tires are pretty good.
Rick
Old 04-11-2014, 10:25 AM
63Corvette
63Corvette's Avatar
Thx. Jim
What is your usage? How many miles per year, and do you drive it in rain, or only dry?
If only a few dry miles per year (less than 2000) then I would recommend Hoosier Street TD "S" tires. Yes, they are an R-Comp tire, NOT recommended for street use. I would still recommend them for your stated needs.
Old 04-11-2014, 12:57 PM
jamesinyork
Default C2 Tires
I'll take a look at these. The car will be driven 2,000 or less a year and only decent dry weather. Thanks.
Old 04-11-2014, 01:34 PM
63Corvette
63Corvette's Avatar
I think you will like them.
To C2 Performance Tires
Quick Reply: C2 Performance Tires
