Fan Spacer Kit Install
I have been having some engine cooling problems with my '64 coupe. I realized that my fan needs to be forward about 1/2 inch more into the shroud (1/2 in the shroud and 1/2 out). When I went to install the spacer, there isn't enough room to get the longer bolts thru the fan clutch to attach that plus the spacer to the water pump. Any advice would be appreciated.
Received 6,946 Likes
2015 C2 of Year Finalist
What's wrong with a five blade fan and a fan clutch
St. Jude Donor '07
Bill
I am trying to get the bolts thru the front of the fan clutch holes, than the spacer that attach them to the water pump. The original bolts were 1", but now I need 1 1/2" and they are to long to fit into the fan clutch holes.
With the proper clutch and fan, it should be spaced properly and work fine without any extra added fixes needed. In my 64, my fan is not exactly spaced 1/2 in /out and no cooling issues. What about the condition of the rest of your cooling system? Pilot Dan
Received 1,843 Likes
Sounds like you are trying to put a spacer between a fan clutch and the water pump?
How old is the radiator and is the fan clutch operating correctly? As others have mentioned, unless the fan is clearly not in the fan shroud at all, adequate cooling on these cars shouldn't hinge on a half inch of spacing.
Good luck... GUSTO
Carmen, I agree with trying the studs first. You should be able to find them at most autoparts stores, such as NAPA. Insert them into the water pump with some red Loctite on them and then slip the spacer and clutch onto the studs. Add the nuts and lock washers and you should be good to go. You could also slot the holes on the fan clutch (open them to the perimeter of the hub) if you want to stay with bolts, but that can be a bit of work.
Good luck... GUSTO
Good luck... GUSTO
