Midyear Front Grille Threaded Studs To Replace Rivets
I checked the archives but I couldn't find it .... Awhile back someone listed the part # and photos of a threaded flat headed bolt that can be used in place of the OEM rivets. Anyone have that info ?
Ray
Ray
http://www.mcmaster.com/#socket-head-cap-screws/=sv4pyg
Received 1,857 Likes
That sounds like the special bolts that Corvette Central sells to attach C1 steering wheel stainless to the painted bell hub.
I think you may be remembering the info in post #7 of this thread:
http://forums.corvetteforum.com/c1-a...-bushings.html
The info is in the attached PDF file.
Dave Z
You got it Davey-Dave, it's that "Rivbolt" that I was thinking of, I should have mentioned that I am looking for these (a total of eight) to attach the grille brackets from the unerhood opening, i.e. the "Grille Mouth" through the front wheel houses. Does anyone here have eight that they would sell ? To me ?
Ray
Ray
Ray
Ray
Do you have any good weld shops in your area? They might have some on hand that they'd let go.
DZ
Try Grainger in OKC.
http://www.grainger.com/product/Weld-Stud-1LAP3?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/1LAP1_AS01?$smthumb$
I just tried these "Rivbolts" on my front grille brackets and they worked pretty well. Looks like they're also good for securing your Midyear door hinge supports. I had to purchase a group of 100 pcs to get the eight that I needed. That leaves me with 92 of these. Let me know if you need any of these, it appears as though I have a few extras ...
Ray
Ray
Ray
Ray
Received 6,943 Likes
2015 C2 of Year Finalist
Why not re rivet the grille it's very easy to do
Ray
Ray
(file photo)
Most industrial strength hairdryers used what is known as a hollow rivet, these were usually peened at the factory requiring a special buck. These molds were used until the early run of the 1967 "Coiffe-A-Rama" model until a factory worker dropped a tool, either a Hamill Bolt-On cap screwdriver or an afro-pick.
(file photo)
(file photo)
rayvaflav (03-17-2017)
Enjoy while you can.
Received 2,686 Likes
Ohio Events Coordinator
C2 of Year Finalist (stock) 2019
St. Jude Donor '14-'15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
Used elastic lock nuts
I used No 10 Stainless steel A316 socket head cap screws on all the body reinforcing brackets and grill mounting instead of the aluminum rivets. I like the clean look on the underside with these. I also used stainless steel nuts and washers. Use as short of a length as possible so you don't end up with lots of thread showing.
I have some more of these, they will also work on the inner door structure at the top of the upper door hinges, different sized rivets were used on A.O. Smith cars if you need them, let me know.
Ray
Ray
