Dashlights
The heater core leaks !! Not so much!! I can't see a big change.
So I have to change the heater core! I did this on an other car already.
I do this from inside, right? Like the service guide says.
Do I have to drain the radiator? Where? Or just lower the hoses at the heater or at the water pump or engine to drain the fluid?
IMO, it's easier to drain at the petcock of the radiator. Level about half way down(about 2 gallons or so in the drainpan) so it's below the heater hoses. Since the heater valve is open most will drain out of the core.
Rich
It should be on the passenger side of the car. Look through the grille opening. It'll be just above a hole in the lower part of the radiator support.
It's possible someone put a plug there instead of the petcock drain.
If so be very careful you don't damage the radiator. If it looks like trouble, maybe go back to the hose removal ideas.
Rich
Rich
