Need help. No heat. 67 l-68 with a/c
I don't have any heat in my 1967 L-68 with A/C. My radiator is full and I checked the thermostat, all ok.
The two heater hoses do not get hot. Is there a cut off valve in the heater box that would cut off water flow thought the heater core ? I thought the a/c version had a vacuum valve to control the heater water flow.
Any help will be appreciated it's 27 degrees outside.
Thanks,
Nelson007
Thanks,
Nelson007
Thanks,
Nelson007
Thanks,
Nelson007
Received 1,048 Likes
C2 of Year Finalist (appearance mods) 2019
Thanks,
Nelson007
Thanks,
Nelson007
Pull a vacuum on the tubing to the hot water valve and see if it will open. You can suck on the tubing to get this vacuum. If the valve opens, then the problem is probably the vacuum valve under the dash. It can stick closed or open. It can be rebuilt, or a new reproduction switch can be ordered. LICS has them.
Larry
http://www.parts123.com/parts123/yb....5Z5Z50000370a#
On your car, it should be on the smaller heater hose (5/8 inch) just a few inches from the firewall and heater inlet connections. The vacuum tube to the valve is a very small diameter rubber hose that should point straight down from the top of the valve.
Larry
EDIT: This is the one under the dash on top of the heater box: http://www.parts123.com/parts123/yb....Z5Z5Z50000370a
This vacuum valve supplies the vacuum to the hot water valve in the engine compartment.
Received 6,943 Likes
2015 C2 of Year Finalist
On the lower heater hose it's a brass valve that's next to firewall/heater box. There are two vacuum lines that goes to it. One goes in though the firewall and to the heater box. The other goes to the intake for the vacuum. When closed it does not allow hot water into the heater core. It's only closed when the AC is on. I would check the vacuum first. And Larry beat me to it
Thanks i can see the valve. Where do I check the vacuum ? There is a hose coming from the valve that goes through the firewall.
QUOTE=Nowhere Man;1588613168]On the lower heater hose it's a brass valve that's next to firewall/heater box. There are two vacuum lines that goes to it. One goes in though the firewall and to the heater box. The other goes to the intake for the vacuum. When closed it does not allow hot water into the heater core. It's only closed when the AC is on. I would check the vacuum first. And Larry beat me to it[/QUOTE]
