Need help...Turn Signals work but No Brake Lights??
Need help...'67 Turn Signals work but No Brake Lights??
Yesterday, I realized I have an electrical issue:
Indications:
1. Brake Lights don't work.
2. Hazards (won't blink...only come on steady)
3. Volt gauge is pegged far left?
4. Turn signals work fine.
5. There is power to the brake pedal switch.
All fuses are good (none blown). My clock went out a while ago and the wipers have never worked...therefore, all other electrical systems are working nominally.
After reading other posts, I suspect the turn signal switch has gone bad?
Anyone have any other thoughts?
Thanks,
Frank
Indications:
Thanks,
Frank
Yep that is the first thing I would look at. 75 bucks and a couple of hours to install. Be very careful putting it in. I had all of mine put together and my signal light would not work. Had to get the wheel puller out again and move a little clip to get them to come on. test it out before putting the wheel and horn button back on.
I'll assume you're working on a 67. Try this first: With the key OFF and the brake pedal depressed, wiggle the turn signal between left/right/off and see if the brake lights come on or flicker. Post back what you find.
mspry - good advice, thanks.
65GGvert - I think I read that on another post and did that last night and nothing.
I have been through the grounds and I keep coming back to the turn signal switch.
Forgot to mention my horns don't work either...
I didn't realize how much goes through that switch...
Yes, 67...should have clarified that at the outset.
EDIT: Just remembered, you said hazards come on steady. Maybe someone with knowledge of the hazard circuit could help. Maybe if the hazard flasher goes bad, the brake lights won't work. Just guessing, never had a problem with hazard or brake lights on a 67.
Best guess without being there is the turn signal switch or the connection between the front harness and the rear harness... Both are suspect and can be the problem. I have an extra rear harness and tail lights that I use for trouble shooting. 30% of the time it's the harness..... 70% of the time it's the turn signal switch...
Hitch
Hitch
All the wiring harnesses are new, however, the turn signal switch is original.
Everything used to work fine. (except horns, wipers and clock)
Brake pedal switch Function Check:
I have 12v at the brake pedal switch on incoming Orange wire and when the pedal is depressed I have 12v on the outgoing White wire.
I know my turn signal flasher is over behind the glove box...then this must be the hazard flasher (yellow)? Sorry for the orientation.
Frank
Frank
If you do end up buying a new turn signal switch, get a good one. It takes just as long to install the import model and they last about a month or so. It is in the plastic itself. The cheaper types are just too flexible and that leads to problems. I changed the one in my 67 telescopic wheel twice before I was able to find a quality replacement.
Good Luck,
Doc
Good Luck,
Doc
Good Luck,
Doc
Good Luck,
Doc
Update...
I installed a new turn signal switch last night.
Brake lights work now.
Emergency Hazard flasher needs to be replaced as well.
I somehow gooned up the brake pedal switch, so that needs replacing. It pulled apart when I popped the plug off and I've put it back together but the contacts and the plunger aren't working together, so my brake lights stay on.
Anyway, thanks for the help. Its just another parts order...more money...more shipping charges...
I love this car and I HATE THIS CAR...money pit.
Happy 4th!
Frank
Happy 4th!
Frank
It's just part of the journey... At least with ZIP in your back yard the shipping should be small or even if you are buying from LIC either or should have the parts to you within a day...
Hitch
Hitch
