1962 Corvette, can someone show the position...
Old 09-30-2015, 01:13 PM
Hall1836
Hall1836's Avatar
Default 1962 Corvette, can someone show the position...
of the distributor tach drive. A photo would be appreciated, I know there will be variations based on timing. Trying to set up new to me dual point distributor.
Old 09-30-2015, 01:55 PM
chris ritchie
chris ritchie's Avatar
On my '62 340 HP car, and all the others I've seen, the tach drive faces the firewall. Not at an angle, but straight on. From that position, the timing is done. Timing will only change the angle slightly. The tach cable will go straight into the hole in the firewall for it. I'm not sure how the distributor is positioned on 360 HP cars ("fuelies") where the hole in the firewall for the cable is slightly off to the side.
Old 09-30-2015, 02:17 PM
MelWff
MelWff's Avatar
Received 1,817 Likes on 1,606 Posts
depending on where the hole is in the firewall the C3 section of this PDF may help
http://www.lbfun.com/warehouse/tech_...stallation.pdf
To 1962 Corvette, can someone show the position...
Quick Reply: 1962 Corvette, can someone show the position...
