Oil consumption !
#41
I am sure someone will set me right here, but my understanding is that, Synthetic oil is just that. It is man made. The molecules are smaller thus allowing the oil to go places standard oil can not. An engine that does not consume standard oil, might leak synthetic. If it already leaks, it will leak more if changed to synthetic.
In the 1990's the OEM's were demanding piston ring sets that controlled oil at one quart consumed in 20,000 miles. That is 25 years ago and that was because of pressure from the EPA. I am sure it is tighter today with higher standards. That is what the Manufacturers demand of the piston ring suppliers of OEM Parts.
After the car is sold they will tell you 1,000 miles per quart is normal to hide from warranty issues.
My Dad has a 2014 Camry 4 cylinder using a quart of oil every 1,500 miles and they were telling him that was normal till I pointed out the EPA demands more than 20,000 miles per quart of oil consumed.
Now they are talking to management to see how they can help.
#42
Received 3,443 Likes
My 2005 Tundra has 61,000 miles on it....guess I got a ways to go!
#43
Received 1,295 Likes
2022 C1 of the Year Finalist - Unmodified
2021 C1 of the Year Finalist - Unmodified
2019 C1 of Year Finalist (stock)
2016 C1 of Year Finalist
I had a 94 Camry (4 cylinder) that went 200K miles. Never burned or leaked a drop of oil.
(it did need a new trans @ 120K however). Sold it for $2500 3 years ago.. I'm sure it's still on the road.
#44
Received 1,843 Likes
While we're testifying.................
I had a '48 Studebaker Champion that used a quart of re-refined oil just to get across town. Population 35,000.
Another one. '60 Buick that looked like a crop duster going down the road. Gave $50 for it. The owner said the engine was shot. Turned out to be a bad fuel pump. Seems the engine vacuum windshield wipers had an assist from the fuel pump. Mash on the gas and it'd quit smoking. Let up on the gas and the smoke would roll. I figured it out when I saw engine oil dripping from the wiper motor.
Had a '58 Biscayne. Cracked piston. Used a quart every 50 miles. Filled it up with 4 1/2 quarts of STP and it didn't use a quart for another 8-900 miles.
I know all about oil burners.
#45
Anybody remember recycled oil ? IIRC it was $0.19/quart in the '60s. I had cars that used so much that I kept 3-4 quarts of this black gritty stuff in the trunk on long runs...
#46
That is what I used in the '48 Studebaker mentioned in the post before this one. It was $.10/qt in 1961-'63 at the corner Payless station. When I went out in the Studebaker on a Friday night, I headed straight for the Payless station to get three quarts of oil for the night. It took a half quart just to get there.
#47
Then there was my Chevy Vega........
#48
#50
Had a 63 Rambler American, three on the tree. Fourbanger used so much oil that the engine compartment became pressurized and blowby came up the steering column and out the steering wheel horn button. Had to open the windows with the heater blasting in the dead of winter.
#51
Guys, I'm younger than some of you being a mere 55, but my lack of common sense has provided me with many 'old fashioned' automotive experiences in many old fashioned cars: anti-foulers on every spark plug of my 1937 straight eight powered Chrysler Imperial....until an old guy (this was the late '80's so I was 'young') told me to rebuild the fuel pump. Fuel pump? Well, it was a dual diaphragm unit, and the windshield wiper diaphragm was blown, causing it to suck oil. $75 later, and I went from a quart every 35 miles to normal. Another Chrysler I had about the same time was a '47 Windsor Highlander, with so much blow-by out the road draft tube, it looked like a train going down the road. Don't get me started about stalling my '15 T at a busy intersection, and having to get the passengers out so I can get out (no driver's side door) and attempt to hand crank the engine.....while people honk and swear.....
#52
Just for the record, I never needed a shiny car to get a good lookin' heifer on a date, or otherwise................
The guys I ran with, it was a status symbol to leave your good car home and drive an old beater.
I had a year old car when I met my wife to be. She got to ride in it once before we got married. In the meantime, the two cars pictured are the ones we went everywhere in. The '57 was a 150 stripper, the '56 was a 9 passenger, factory air, PS, PB. I gave $140 for the '57 and I think $150 for the '56.
Also for the record, we used to snicker and laugh at the guys that could afford a new Corvette back then. We'd tell them they had to have a fancy car to get a girl. They didn't like that much.
PS. Neither of those two beaters above used any oil (to amount to anything) either.
#53
What I find amusing is that most of the supposedly 'poor', supposedly underpaid people running about today wouldn't be caught dead in some of the old clunkers that we were glad to have 'back in the day'...
#54
Received 3,043 Likes
St. Jude Donor '05
Lttle oil burning is normal here there they will all do it at some point. My 02 5.3 has done a qt every 1000 now less since brand new so what
Mike you jogged my memory of a guy I worked with yrs ago
bought a brand new 84 toyota pu and NEVER changed the oil, not even once
It gave up the ghost at 65k. Pulled the 22r out stuck a used 20r in, bought that thing cheap drove it til it had 320k on it.
As a kid remember the neighbors Valiant (60 something) always blew oil around the compartment and tossed headgaskets constantly Bottom end went a long time
His VWs never used or LOST a drop they had to come out and get rebuilt before they hit 3k most times. lol
#55
#57
In the dim reaches of memory I recall one of those Rambler engines (6cyl ?) had a hollow head stud which the oil was supposed to pass through to oil the valve train. We traded in one of those jewels 'back in the day' where the stud had been replaced with a solid version.
The valve train had been running 'dry' for God only knows how long...clattering like hell...
#59
