OT...Can Someone Decipher the Differential numbers for me...
I swapped rear ends on my Pickup and the speedo is waaaay off...here are is what i found stamped on the tube thats goes int diff..
Its an early 80's diff...
TUM C OR 'G' 351 2 EST...the "est" is stamped Vertical if that means anything..
TIA...
TIA...
Is it a 10 bolt or 12 bolt rear cover?
Are you sure you read those numbers correctly? C381 2 would be March 3rd 1981 2nd shift............
I can't find an axle code TUM. TAM would be a 2.73.
But at least you gave me something to start with...
Whats your source for looking this up?
Thanks...
:leaving :
