Torque Thrust "D'" 65 coupe
Torque Thrust "D'" 65 coupe new photos
Looking at torque thrust D rims. What size rims(width/backspacing) will fit my 65 without clearance issues? What size tire will also fit?
I know this subject has been posted and reposted so please bear with me. Looking for wheels and tires for my 65 coupe. Have seen a prior post stating the torque thrust II have a clearance issue. The rally rims that were on the car now rub since I welded the parking brake tabs back on. What tire and rims are being run without interference? Please post photos rim size, offset, and tire size if possible
64Corvette (05-10-2016)
Wow, never heard of putting the parking brake brackets back to stock. If you do that, then a lot of wheels and tires will rub.
I might add i also have disc brakes, the 4.25 backspace will put the wheel further towards the middle of the car, so you will have less clearance next to the brake line and shocks.
When i was ready i bought one rim and one tire and checked the wheel fit, if it looked ok when just sitting on the lugs and you cleared the caliper then mount the tires on the wheel. Once the tire is mounted on the wheel its yours. If it not going to work, you only have to send one set back.
last person just removed parking brake and all the hardware, was unaware of clearance issues wish he moved to top, just want to return to stock, may move bracket to top now that I know why he eliminated it .
Melting Slicks<br><img src="/forums/images/ranks/3k-4k.gif" border="0">
Received 1,946 Likes
I have TT Ds on my '66. They are 15 X 6 with a 3mm offset and no spacers. Tires are 205/65-15.
Received 3,443 Likes
You nailed it, Warren. LOVE the look!
Received 1,858 Likes
This recipe has never changed. 15" x 6" rims, 3-5/8" backspacing, 205/75 or 215/70 tires. Anything else is trial-and-error for interferences on a stock body.
torque thrust w/pictures
Thanks to all that responded, went with 15x6 3-3/4 backspace. hope photos come through.
There are some very pretty cars in this thread but I really like a white mid year. And thanks to all who submitted wheel and tire sizes, I am wanting to put on a set of TTs on my Corvette!
fastrad, trq thrust D's look great on your '65 as well !
