C2 speedometer/tach remove and replace
I do not want to pull the cluster - but, I have a tach problem (noise/erratic needle). Anybody pulled either instrument for repair w/o removing the cluster assy?
thanks
Bill
thanks
Bill
Received 6,944 Likes
2015 C2 of Year Finalist
Unless you got hands and arms of a infant your going to need to pull the cluster
Received 2,127 Likes
As stated above, you must pull the cluster. We all know its a challenge, but you can do it. All the details have well covered here. Dennis
IF your tach is distributor driven you may find the gauge is not your problem...could be worn distributor parts....could be a dry cable....could be too severe an angle on the cable at the distributor end.
Do a proper diagnosis before snatching delicate parts out...
Some have used this fliz (I don't run one):
http://www.zip-corvette.com/62-74-ta...e-adapter.html
