design flaw in C2 soft top frame
My original soft top has a hole worn through the liner in a common location. The culprit is a protruding "appendix" with a small rivet that seems to serve no purpose and this occurs on both sides just above the seat backs. I tried determining if it is some kind of stop but the fabric gets in the way when folding and I've never had the fabric off. These photos are on the passenger side. I wrapped both with a heavy dose of electrical tape, hoping to reduce the abrasion before it goes all the way through. Any ideas why this destructive protrusion is there?
I know nothing about C2 tops but that appears to be a stop for the bow. It probably positions the bow when the top is lowered. Rather than padding the stud you might try applying some form of rub material to the top with contact adhesive.
But - I have a suspicion that what is rubbing the hole is the bottom of the bow seen in the lower picture. It looks like it's rubbing a similar hole in the raised position. I bet the other hole is where is rests in the folded position. You might have more luck padding the corner on the end of that bow. Don't know why that area couldn't be flattened when ever the top gets replaced. The stud you mentioned is probably shielded somewhat by the bow laying on top of it when the top is folded. I doubt it's the problem - but I well could be wrong.
Great observation Dan. I hadn't noticed the other hole until you pointed it out. What surprises me most is the lack of other comments on this issue, since I believe it is pretty widespread. Some clever person has a solution and is holding out... btw, the 50 year old top is in otherwise very good condition so I don't plan to ever replace it!
Probably the reason you aren't getting much response is that no one has an original top or one anywhere nearly that old. That's quite remarkable. But this will send you back to the top so maybe someone will weigh in.
Good luck with preserving it.
My 20 year old top is just the same, that pad is pretty thick, but my hole has a ways to go before clear thru. Next top I'll see if I can smooth that end off a little bit. I'll do something like you did to keep it from rubbing any more.
You could prob find a little plastic cap to go over that nub and that might help...C1s/C2s seem to have distinct 'pinch points' on the tops that are problems when the tops are 'stacked' in the storage well. I have a whole routine on my C1 where I put my hand inside the partially folded bows and 'karate chop' the top material out of the obvious pinch points before lowering the ***'y completely and that has saved a lot of problems. Might not work in this case. I also put a folded, white washcloth on the outside in between the bows so the folded 'stack' isn't as tight. It means I have to push on the deck lid a little to close things up but that has been less harmful than the top getting boogered up.
But really ? At the end of the day you have a 1/2 century old, original top with a little frayed spot in it that's not even a hole ? I wouldn't call that a design flaw by a long shot...
As my brother often tells me, "You're hollerin' before you're hit!"
It's the good and the bad of "survivorship". I try to keep the original parts functioning the way they were made, and at the same time enjoy driving the car. Saves money buying overpriced parts but unnerving when stuff starts to go bad. The car already has the awards and documentation out the wazoo, so nothing left but tender loving care and enjoy the occasional ride.
Tloner (06-02-2016)
DUB
From your pictures however, that top frame looks to be in amazing condition - no sign of surface rust that I see. It could pass for a frame that's just a couple years old. It that is an indication of the rest of the car's condition, it must be a really nice original.
survivor66 (06-01-2016)
DUB
