[C1] water pump bolts came loose again
2018 C1 of Year Finalist
This morning, I went out to the garage and noticed there was quite a puddle underneath my corvette. I checked the fluid and it was anti-freeze. The driver side bolts backed out slightly enough to cause a leak. I guess I will have to check them before I take any more rides.
Modified Front Motor Mount Bracket
Jim, you'll probably be fine after tightening up the water pump bolts. In my case, I had a couple leak issues at the water pump on the '61 and decided to modify a new mount to pick up the lower block holes.
Mike T - Prescott AZ
Try using some split ring lock washers under the head of the bolts.
I have not tried that. I thought the ARP bolts would torque down really well. Maybe my bolts are getting lose from chassis flex coming off the line from so much torque.
Received 3,443 Likes
I ran into this a year ago. It was recommended to me by this forum to use Permatex non-hardening sealer on the gaskets. I used it on the bolt threads, too. No leaks. If it leaks again, the mount is getting modified. It's an asinine design, and a major reason my car was mothballed for 20 years before I got it.
[QUOTE=jimh_1962;1592709216]I have not tried that. I thought the ARP bolts would torque down really well. Maybe my bolts are getting lose from chassis flex coming off the line from so much torque.
Sounds like your water pump doesn't have the correct torque rating.................
Permatex #2 here.
You have to drink the Kool Aid with the old C1s. The engine mounting is odd, the clutch bellcrank "single shear" design sucks, and, oh boy, those windshield wiper/washers!
Part of what makes the cars endearing to some and despised by others...
I think I just need to check them ever so often is all. Really I need a checklist board on my wall and keep track of what I have done with dates. Or keep a log book.
I have always used Locktite and never had a problem. I did have a broken bolt many years ago when I bought the car. I always tighten once and After I have driven the and then Tighten again. No leaks.
Received 6,551 Likes
C2 of Year Finalist (track prepared) 2019
A friend who vintage races his '57 used to have trouble with the WP bolts working loose. For him, the solution wasn't just split ring lock washers but "high collar" split ring washers.
I suspect Loctite would have accomplished the same thing, but this is another option.
Jim
Jim
When I rebuilt my engine I had the holes drilled and the pins installed. i haven't had a leak since. The other plus is, you can change the water pump without blocking up the engine.
Received 3,773 Likes
2023 C1 of the Year Finalist - Modified
2015 C1 of the Year Finalist
This problem/issue has been occuring since these cars were built new. And there have been multiple "fixes" for the problem. Klaus' and Mike's above are among the better fixes. I am doing a fix similar to Mike's above using thick stainless and bolting it to the crossover mount.
Below is my mockup. The next time I have the water pump off I will install the additional braces.
Also, something not mentioned, is the gaskets BETWEEN the cross over and the block. As the engine torques back and forth, these are the gaskets which become more damaged (consequently a leak) rather than the gaskets between the cross over and the pump. I frequently check the torque on the 4 bolts. BUT, I have replaced the 4 water pump bolts with stainless studs/nuts. This make everything easier to work on, PLUS, with stainless studs, they are not subjected to rusting issues in the block like regular steel bolts do.
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
Another fix is too make sure you pre-load the cross bracket in the direction of the engine torque as you tighten the bolts, so when it does try to twist it's got no where to move. Lift up on the drivers side, down on the passengers. (if memory serves me right?)
Always use lock washers and a good sealer.
TheCar (07-27-2016)
Side question.....what color is that cross brace supposed to be? Black or Chevie orange?
Chevy Orange, from what I've seen. Also, good point on pre-loading the mount so it can't move during engine torque. I read about that previously, and clocked mine that way when I did the repair the right way, the second time.
Kerrmudgeon (07-27-2016)
I don't know about this "pre-loading" and all these extra brackets. The only way that it would be needed is if the bolt holes in the mount were enlarged due to corrosion. If the mount is in good condition, you shouldn't be able to twist it at all. Like I posted above, no leaks for me in over 42 years.
