wrong stamp on a rally wheel?
I've got a set of rally wheels from our '67 and noticed one of the wheels looks like its stamped DG instead of DC? I looked up the DG code and it looks like its a 14" wheel code so I don't think the tire would have even fit on the rim. Could this have been miss-stamped?
If its a 14" wheel then, NOPE...those wheels i believe went on Camaro's...
I found this list of codes...
XA 14X5 B-3 1/2 67 Chevy II with drum brakes
DA 14X5 B-3 7/8 67 Chevy II RALLY with disc brakes
DG 14X6 67 Camero & Chevelle with dics brakes
XB 14X6 B-4 3/8 67 Chevelle SS, 68-69 Chevelle with F-70 Tires, 70 Chevelle
XN 14X6 B-3 3/4 68-69 Camero & Nova with drum brakes. Different shaped outer
AE 14X6 B-4 3/8 70 Chevelle Station Wagon
XG 14X6 B-3 7/8 68-69 Camero with dics brakes, 68-70 Chevy II/ Nova with disc brakes, 69-69 El Camino without disc brakes. Wider drop center than normal
DE 14X6 B-4 3/8 71-72 Nova & Chevelle, 6 hole wheels
YW 14X6 B-4 3/8 Exactly like XB, may have come on same cars
YJ 14X7 B-4 3/8 69 Camero/ Chevy II L72- ZL1, 70 Nova
AV 14X7 70-72 Camero, 71-72 Nova, 6 hole wheel
XT 14X7 L72- ZL1 Non Rally Wheel
YA 14X7 B-4 3/8 69 Chevelle SS Wheel
AO 14X7 B-4 3/8 70 Camero &69 Chevelle SS Wheel
DB 15X5 67 Passenger Cars with disc brakes.
DF 15X6 B-4 1/16 67-68 Camero Z28
DC (BIG) 15X6 B-3 1/2 67 Corvette, No other stampings on rim
DC 15X6 B-3 1/2 68-70 Passenger car, 67 Passenger car (early models)
FI 15X6 B-3 1/2 68-70 Passenger car, 67 Passenger car (later models) Rivited instead of welded together
YS 15X6 B-3 1/2 68-70 El Camino
FW 15X7 B-4 1/4 71-up most any GM
AG 15X7 B-3 3/4 68 Corvette (will take 15x8 Beauty rings)
YH 15X7 B-4 1/4 L72- ZL1 Z28 Rally 69 narrow drop center
AD 15X7 B-4 1/4 L72- ZL1 Z28 Rally 68 wide drop center
AV 15X7 70, 71, 73 CAMARO Z28 5 spoke wheel
AZ 15X8 B-4 69-82 Corvette
C2 of Year Finalist (stock) 2019
15 inch DG coded rally wheels are correct for January to March builds. I had an original 67 Coupe built in Febuary that came with five DG coded wheels.
I've posted this a couple of times - it's the best article I've come across on the stamping of '67 Rally Wheels - written by Wendel Hans.
This is the spare that was with my car, an early FEB build, when I bought it. Never used and it's a DG rim. The other wheels were mags.
