Getting a new battery any sugs?
Old 02-06-2017, 05:44 PM
  #61
Mikado463
Support Corvetteforum!
Mikado463's Avatar
Originally Posted by rtruman
I use the tender on generators and lawn equipment only
Wrong ..........trying owning a new Vette and let it sit for even a couple/three weeks. There's enough parasitic draw that you'll have a dead battery !
Old 02-06-2017, 06:09 PM
  #62
rtruman
rtruman's Avatar
I don't let them sit longer than 3 weeks had no problem with this one .
All others were Midyears .
Where I use a knife switch been doing that for 20 years good results. My RV has two 6 volt batteries in SERIES
I have that plugged in all winter only because most RV people keep them on shore power all the time even in storage.
Old 02-06-2017, 07:32 PM
  #63
Mikado463
Mikado463's Avatar
nice C6, had one myself ..............question......why did Chevrolet promote (as an option) a battery tender with your car ?
answer - because IT MADE SENSE !
if you don't think the parasitic draw of a modern Corvette will not drain a battery you're living under a rock. Drive it daily or at least two three time a month fine but check over on the C6 forum and see how they make out with the 'hanger queens' ........ thus the battery tender !
Old 02-12-2017, 03:48 PM
  #64
daz_au
daz_au's Avatar
Dont mean to dig this up from the dead again, but I have had an interesting experience with the dead redtop I mentioned in a previous post.
The car with the 12 y.o. optima was stored and I generally disconnect and forgot. I jumped it and ran it for a while and the battery would not restart so I assumed it was dead. Then I read that Optimas discharge very deeply, meaning that even when charged by the alternator for some time can still appear discharged.
I needed the car going so I grabbed a cheap battery for it but put the optima on my charger that supports AGM batteries and left for 3 days. The voltage came right up to 12.6, so I disconnected and left for 2 weeks off the charger and checked yesterday and still 12.6. Then I put it in the car and it started it no problem.
So maybe there is life in this 12yo optima yet !
Old 02-16-2017, 03:20 PM
  #65
babbah
babbah's Avatar
Optima Batteries = I had 2 of them - both failed in 2 months. Never Again!
Old 02-16-2017, 06:08 PM
  #66
daz_au
daz_au's Avatar
So what happened, did they test them, replace or refund under warranty ?
As per my post above it seems they discharge so deeply (for example when leaving lights on, storing connected etc), that they sometimes look dead when they aren't. Some electronic chargers will see them as a lost cause and refuse to charge them.
I was ready to throw mine out when I read about this, but its back to life. I wonder how many of the fails you hear about are really dead.
Old 02-16-2017, 06:27 PM
  #67
rtruman
rtruman's Avatar
I don't trust these batteries they bring down Airplanes ,catch Ferraris and corvettes on fire.
Why invent the wheel
Old 02-16-2017, 10:16 PM
  #68
Mikado463
Mikado463's Avatar
well duhhhh, how would we enjoy our Corvettes ??
LOL, bustin' your stones a wee bit 'rt', for I suspect you meant 're-invent' !
Old 02-17-2017, 06:05 AM
  #69
rtruman
rtruman's Avatar
got me on that one ,if a battery last a lone time with no problems don't reinvent the wheel
Old 02-17-2017, 10:01 AM
  #70
Mikado463
Mikado463's Avatar
again, true and again, I've yet to see a better battery than Odyssey
Old 02-19-2017, 10:37 PM
  #71
babbah
babbah's Avatar
Amen Bro! My Odysssey Battery is the best battery I have had in my Vette during the past 50 Years!
Well worth the extra money!!
Drop it in and forget about any battery issues or replacements for the next 10+ years!!
End of story! Get one!! ðŸ‘
Old 02-20-2017, 06:18 AM
  #72
rtruman
rtruman's Avatar
Do they look stock and have the posts where we need them
Old 02-20-2017, 12:01 PM
  #73
Mikado463
Mikado463's Avatar
you decide .............
http://www.odysseybattery.com/perfor...batteries.aspx
looks like a battery to me !
Old 02-20-2017, 02:08 PM
  #74
rtruman
rtruman's Avatar
Actually the post would be better in the middle like the picture shows .
I use a knife switch it would work better .
Perfect for where the battery is located in the corvette.
Thanks for the tip saved the link
Quick Reply: Getting a new battery any sugs?
