C1 with C4 suspension
Has anyone done a C1 conversion to the C4 suspension, like Paul Newman or used a prefab tube frame and later C4 suspension on a C1 car? I need some advice.
Re: C1 with C4 suspension (PhilG)
Yes, I am in the process of doing my 62. I did a Paul Newman Conversion & used all 96 suspension with a ZZ4 crate motor & 700R4. I would highly recommend Paul. He does excellent work. There are some things that you will need to work out on your own or go to some other places to purchase. I have my chassis finished & am now working on the body. You can e-mail me for more info & pics. Let me know info you are after.
Live Free or Die
Re: C1 with C4 suspension (jron)
I've got a 57 with a SRIII motorsports tube frame.
It is flat out awesome!! I'M me if you need any info on this package.
Mike at SRIII is a great guy to work with. :cheers:
St. Jude Donor '03, '04 & '05
Re: C1 with C4 suspension (Duntov-097)
You have to check this out - very interesting conversion.... great car - good info http://temp.corvetteforum.net/c5/richs7/index6.shtml
Hi phil this is a project I am planning to do also I am in the negosiations on a 1962 with a shot frame.I was wondering to all who have done this prior.
What made you chose the tube frame over the standard frame is it just the cool factor?
I want to do a big block and a auto trans. I will be following this post closeley
Phil:
I just finished my '62 frame conversion about a month ago. Mine was done like the Newman conversion except I did all of the fabrication myself.
At Carlisle this year there were several vendors selling tube frames and a company (from Texas I think) that has a rectangular tube frame that looks sort of like an original C1 frame except the side rails are doubled and it has no "X" member. A friend of mine bought one of these frames, which is supposed to be delivered in October, so I can get you more specific information on it if you wish.
One of the main differences between the tube frames and the Newman conversion is that the suspension is narrowed on most of the tube frames - at least the ones I looked at before starting my project. That means that in the rear you have to shorten the half shafts and the tie rods and use a non-stock spindle support rod (camber adjustment link). Because of the narrowed track, most of the tube frames do not use the stock C4 front crossmember like the Newman conversion does, but bolt the front control arms directly to the frame. The tube frames usually use coil-over shocks whereas with the Newman system you can use the stock transverse springs in front and rear. The narrowed track on the tube frames probably makes finding wheels/tires that will fit under a C1 body an easier proposition. Both systems have pros and cons. I went with the Newman type mainly because I wanted to stick with the stock suspension pieces.
If you are going to have your old frame converted, Paul Newman is probably the best, in my opinion. Paul is an extremely nice, helpful guy and the workmanship on his frames is excellent.
If you are thinking of modifying the frame yourself, you can look at my website ( web.infoave.net/~cbernhardt/c1frame.html ) and, if you have any questions about how I did mine, I would be glad to help.
Charles
Charles
Live Free or Die
Re: C1 with C4 suspension (Ih2lose)
h8 to lose
I chose the tube frame mostly because I drive my car hard and wanted the weight savings and did'nt really want to modify a 40+ years old frame. IMHO even the best frames have been weakened though 40 years of use.
Buying a new frame to convert was just to expensive for me. I also like the coil overs on all four corners on my tube frame
My rear suspension is stock width allowing me to run a 16X8 wheel with 2 1/12 inch front spacing and a 245/50/16 tire. Any 16X8 93-03 F-body wheel will work. This gives you a huge selection of aftermarket wheels. narrowing the rear track will allow you to run a wider wheel and tire.
Both options have pros and cons, but they all seem to have one thing in common. The people who do it love them.
Good luck.
Good luck.
Phil,
If you want more information on a Newman conversion just drop me an e-mail. I'd be glad to try and help.
Rich Lagasse
Rich Lagasse
