[C2] 63 Muncie hard to get in first gear...
#42
Received 3,443 Likes
I respectfully have to disagree with this. Gear oil installed a couple of years ago will be fine for the next ten or twenty years. Unless there's debris or contamination in it, which is very doubtful in such a short time. Frank will be able to check the oil condition when he checks the mechanicals...my money is on another issue.
#43
It got GL4 when I replaced the side cover not that long ago... The car actually had a slight grind on second gear downshift when I got it but the fresh oil cleared it up..
#46
Received 1,126 Likes
I am on the mend and I was just allowed to start driving a couple of weeks ago. It was tough sitting in the back seat and letting my wife drive me around for over two months. I had to chew on the pillow that was between my chest and seat belt to avoid being a backseat driver!
I still can not lift anything over 10 pounds so it will be a while before I do a 4 speed or rear end for someone.
Joe
Frankie the Fink (01-15-2017)
#48
St. Jude Donor '07
slightly off topic, but on the subject of a transmission oil change...
I first filled my MY6 with GL4 and had a synchro clash; I drained it and replaced with ATF and problem went away.
I realize the a Muncie is probably not capable of handling ATF, but it does go to show that a lubricant change can help.
Bill
Bill
#51
Bought a car that was hard getting into 1st all the time----running, not running, clutch in, clutch out. Took the side cover off and the shift fork was only inserted into the first shift detent bar (pic below of bars for reference). This jammed the shift fork against the second detent bar. Luckily it didn't wipe out the fork or the groove in the gear slide. Popped the fork back under the second detent bar and all was good.
#52
#53
Bought a car that was hard getting into 1st all the time----running, not running, clutch in, clutch out. Took the side cover off and the shift fork was only inserted into the first shift detent bar (pic below of bars for reference). This jammed the shift fork against the second detent bar. Luckily it didn't wipe out the fork or the groove in the gear slide. Popped the fork back under the second detent bar and all was good. [/IMG]
The only way I can see that happening is the shift lever came loose allowing the fork to move inward.
I have never seen a side cover with needle bearings before. Is that a replacement cover?
Joe
#55
OK - you probably have something different going on than what is causing my stiff shifter action. But I'll be curious to see what you turn up.
#60
Received 1,843 Likes
Would it be best to lock this thread down, get off the key board and out in the garage and see what is going on?
The three days spent here on guessing could have had the car repaired and back on the road.
