[C2] C2 and C3 Jacks
C2 and C3 Jacks
I have a question to pose to the membership.
Is a stock c3 jack interchangeable with a C2 jack? By that I mean will a c3 jack fit into the jack holder found in the well behind the drivers seat in a C2.
I am looking for a stock jack for my driver quality c2. I found a jack listed on Ebay as a "1963-1982 corvette jack and wrench and hold down spring early c3". Is this description correct? Does a C3 have the same dimensions of a C2 jack? Based on the ad in Ebay would it be reasonable to assume that the C3 jack would fit into C2 the same way that a C2 would fit into the jack holder in the well behind the drivers seat?
Any information would be helpful.
wpbailey (02-25-2017)
You should be able to fit the later jack, into a 63-67 jack compartment.
68's used a jack very similar to the 66-67 Type 3. The 69-82 jack has a wider base, but it's still not that much different in size than the 63-68 jacks. 63-68's used a 5 1/4" long jack spring, the 69-82's used a 5 1/2" long spring. A quarter inch isn't much, but I would think that if you can't pull your original spring far enough to secure a later jack, then a switch to the 69-82 spring, should do the job.
Received 6,946 Likes
2015 C2 of Year Finalist
Corvairs used a similar jack as well
While it is not correct for your C2, I think the wider base on the C3 jack makes it a bit safer should you actually have to use it to fix a roadside flat. Also as I'm sure you've already discovered, a C3 jack can be had for a third of the price of a C2 jack in comparable condition.
Do you know if a C3 jack will fit in the C2 well behind the drivers seat? I am trying to determine if the long screw that goes threw the jack is longer on the C3 than the C2.
C2 C3 jack differances
It is good to know that the C3 has a wider base. Understand about the safety of the jack. I do have AAA road service.
Thanks for your help.
There are some c3 jacks that are a bit longer and will not fit in the c2 storage well.
Measure before you buy.
Starting in 1976 the base was 9" x 4 3/4" and the top plate was 5 1/2" x 1 3/8".
I'm not sure about the 68 dimensions. All I know is that the base is smaller and more like the C2 jacks.
Since 1970, the Corvette Parts Books have indicated that the 69-82 jacks can be used in place of earlier jacks, by using the longer hold down spring. I can't say for sure if the later jacks will fit in the 63-67 well, but Chevrolet seemed to indicate that they will?
not a mid year jack
Screw Length
Thanks for the pics and information. Can you tell me how long the jack is when in the full down position? Is it less than 15 5/8 inches? Measure the widest point of the jack in the full down position. I think a C3 jack is 15 5/8 inches which means that a C3 jack is too wide to fit in the C2 well in back of the front seat. Your measurement should answer the riddle.
Last edited by wpbailey; 02-25-2017 at 10:16 PM. Reason: I needed to change what needed to be measured.
