Old school Vs smart charger
Alright folks. I have a cheap smart charger and it is great. Problem is, if I leave the lights on or keys on well it sucks the battery all the way down to give me a fault on the smart charger and it will not charge. So I need to give it a little charge from my dads old school charger to get a couple volts in there to bring her back. So the question is. What is the best old school charger out there? Nothing to crazy I just need it to give me a boost
Received 1,843 Likes
I think you should install a red flashing light on the dash anytime your ignition is on or your lights are on.
I see from your profile you have a '63 model. The year that they had an ACC position on the key switch.
Get in the habit of taking the key out of the ignition when you turn it off and that will eliminate that problem. You shouldn't be able to take the key out with the switch in the ACC position.
Received 6,946 Likes
2015 C2 of Year Finalist
Or buy a battery cut off switch and turn your car off every time you park it
Well I still have my "dumb" 10 amp Western Auto charger from 30 years ago and still use it sometimes.
Received 3,443 Likes
I'm an old school guy. Experience has taught me that new-school stuff doesn't hold up.....usually a failed 39 cent component in the circuit board that can't be fixed....and the whole thing is junked. I love old equipment that I buy once and use for 30 or more years. That said, I ALWAYS pull the key OUT of the ignition and place it on the dash or seat, or in my safe. Have had a TON of cars at work that drain out overnight with the key in but not on, not to mention auto door locks that lock the car with the key in the ignition.....a real drag. So: always remove key, and always use a stone-age charger....but you have to remember to turn it off!
I agree about turning car off. I have a disconnect. But I was working on it and left the key on. Car is up on jack stands. So oops here. Just need something for the next oops.
Received 1,121 Likes
2017 C2 of Year Finalist
Whenever I have a dead battery that won't let the smart charger come on. I just hook it up in parallel with the vehicle battery and the smart charger turns on. Amazingly it will hold 12 volts for months just sitting on the bench without charging.
Good luck... GUSTO
Received 2,347 Likes
The 63 has the ACC position, and most 63's allow you to remove the key with the switch in any position. The habit to learn is to rock that he switch back and forth to the lock position after you pull the key out.
Any 2/10/50 amp manual charger will work.
