[C2] 15x7 wheels on a stock C2?
Old 03-17-2017, 01:12 PM
  #41
forzav12
forzav12's Avatar
Originally Posted by TCracingCA
Most won't have the budgets to run tires like the Avons and Michelin TBs and the repop Pirellis or other marginal usage on the street tires!
Then you have a category that is getting better where like F-70 or L-60 reproduction type Goodyears and Firestones are. Wing repop' d And those aren't what I would call performance tires, even though being made of modern rubber! They don't stick like the ones above!
Then the last group that that has been around is the last BFG holdout, who offers sizing for 8-10 inch rims (275 & 295 15s). They are cheap and are street safe!
And I hear rumors of more vintage repops!
Our cars are pretty high strung rides, so we either follow them with a chase or support vehicle carrying an extra set of rims and race tires or we are trailering now if further out than a hundred miles! We burn more than a whole tank of gas on a hundred mile round trip too! We used to use the BFG R1/Gforce race tires sold special order and drive out carefully on those! But they weren't build for commuting to and from events!
The 168mph rated TB-15 rally tires at 5 bills a pop each are what I am looking to mount up next! At the big Porsche Event here, I found some of the RGruppe crowd on that rubber, but with mixed reviews and the negatives were mostly on the expected life expectancy on the street! But those guys running said better results than what else is out there!
And 7 inch rims should not be hard to shoe! I haven't shopped for those small sizes lately, but maybe 15 inch in the 205-235 range in a true apeed rated high performance tire! I don't need tires like that in that smaller size! My C3 driver, I just op that on BFGs, and the suspension is pretty built, so the tires are the disappointment, but it is fine! I just drive it within it's ability with those tires! They get greasy fast! Like to slide around!
Good points. I've discovered that I can run my "Rtype" 911s for a very long time on street legal "race" rubber as they are so much lighter than the Corvettes. Used to drive 100+ miles to Willow on A008R's, run the vintage race in C/P and drive home. No problem in the 911's. The Shelby and Corvette are an entirely different matter as they wear the tires out much quicker. I still like the speed rated Pirellis on the street and open road rally events as they just work better than the BFG(and look better too). The Avons are much stickier but do wear quickly. Our 67 will run above the speed rating for the BFG without difficulty and some of our events feature extended times at high speed-just not comfortable on the crappy "S" rated BFG. Too bad they don't make the old ones that Greenwood used to run at LeMans!
Once we were short on time and ran H rated Yokes on one of our Carreras down in Mexico. Warm,extended operation well over 100MPH, thought we'd be fine. No issue during event. Checked out tires when we returned and they were coming apart. Never again.
Old 03-24-2017, 08:11 PM
  #42
Bizzarrini
Bizzarrini's Avatar
Just got sent my new wheels and Tyres , 15x7 TTDs and Avon CR6ZZs. I will report how good they are.
Old 03-24-2017, 08:22 PM
  #43
forzav12
forzav12's Avatar
Those will look and drive much better! Never was a fan of polished TT's.
Old 03-24-2017, 08:28 PM
  #44
forzav12
forzav12's Avatar
Bizzarrini-we did battle with one of these on a rally in 2015. Not a Bizzarrini, but pretty close
Old 03-24-2017, 09:01 PM
  #45
FLYNAVY30
FLYNAVY30's Avatar
Received 2,366 Likes on 1,034 Posts
Cant wait to see how they look...giving serious consideration to that exact set up
Old 03-24-2017, 09:29 PM
  #46
ganshert
ganshert's Avatar
This is what 15x6 TTDs with 215 70 Cooper Cobras looks like. I erred on the side of caution with width, I'm not suggesting you do the same I'm just showing off my wheels
Bizzarrini (03-25-2017)
Old 03-25-2017, 03:01 AM
  #47
Bizzarrini
Bizzarrini's Avatar
Forzav- looks like a 7 litre Grifo, much more refind than the Bizza..... But not such fun!
forzav12 (03-25-2017)
Old 03-25-2017, 09:06 AM
  #48
FLYNAVY30
FLYNAVY30's Avatar
Car looks great!! Im leaning towards 225/60/15...I like the 15" look but slightly shorter sidewalls.
ganshert (03-25-2017)
Old 03-25-2017, 10:25 AM
  #49
forzav12
forzav12's Avatar
Yes, it was a 427 powered Grifo-fast, and the driver knew what he was doing! Yours looks incredible!
Old 03-25-2017, 01:17 PM
  #50
rayvaflav
Support Corvetteforum!
rayvaflav's Avatar
My local OKC bud campaigns his Bizza Competizione at most of the Historic races. Set the timing ? Simply access the distributor through the top of the dash.
Ray
Old 03-26-2017, 02:46 PM
  #51
Bizzarrini
Bizzarrini's Avatar
Quite correct Ray, the engine is set so far back in the car. It is considered the first front/mid engine car built he also felt that the small block Chevy was the best engine available so Bizzarrinis used the 350hp Corvette engine. Quite a compliment coming from the man who was Ferraris chief race engineer and also the designer of the Lamborgini v12 that stayed in production til the mid 1990s.
Old 03-26-2017, 08:36 PM
  #52
LouieM
LouieM's Avatar
Received 3,039 Likes on 1,252 Posts
Originally Posted by FLYNAVY30
So heres the exact look Im going for....
Let me know what you think, it almost looks like this car is running 16s, but its hard to tell. I really wish I could find the wheel size, back spacing, and tires size. This is an original '63 Z06 that sold at Mecham a while ago....lots of info on the web site, unfortunately, nothing on the wheel/tire set up.
Your wheels appear to be PS Vintage Wheels model TA-1 in 15" size.
http://www.psvintagewheels.com/products.html
I run these wheels on my 67 in 17X7 size with 4.75 backspacing with stock fenders and the parking brake brackets moved to tops of the rear trailing arms. Unfortunately, I can't post a photo because Photobucket seems to have gotten screwed up lately.
Lou
FLYNAVY30 (03-26-2017)
Old 03-26-2017, 09:13 PM
  #53
FLYNAVY30
FLYNAVY30's Avatar
Thanks Lou....I actually tracked down some of your old threads from a while back when you went from the 15s to the 17s. I was mostly interested in the 50 series tires you were running on the 15s. Great looking car!!
LouieM (05-15-2017)
Old 05-15-2017, 04:30 PM
  #54
Bizzarrini
Bizzarrini's Avatar
Finally got new wheels and tyres on my Vette. To me they look great and they really drive well. The Avon tyres really tick all the boxes for me.
Old 05-15-2017, 04:51 PM
  #55
Revfan
Revfan's Avatar
Wow... what a one-two punch you have!
Old 05-15-2017, 04:54 PM
  #56
oldpainter
oldpainter's Avatar
AR 515. 15/7inch 3.75 inch BS. Running 235/60/15 and 245/60/15 TA's.....
Works for me.
Old 05-15-2017, 06:33 PM
  #57
FLYNAVY30
FLYNAVY30's Avatar
Awesome!!....any more photos??
To 15x7 wheels on a stock C2?
Old 05-18-2017, 04:57 PM
  #58
Bizzarrini
Bizzarrini's Avatar
Some more pics.... She is still sitting a little high but I feel the springs wil take a set after a little more driving!
Old 05-18-2017, 07:28 PM
  #59
FLYNAVY30
FLYNAVY30's Avatar
very nice! what size tires did you go with?
Old 05-19-2017, 07:33 AM
  #60
Bizzarrini
Bizzarrini's Avatar
Avon CR6ZZ 225/60/15 on 15x7 rims.
I was amazed how different the driving characteristic are from the Goodyear Eagle 225/55/17 on 17x7 that came with the car. On the Avons the car is much more stable, less wandering and a much softer ride. This is without in any way changing any suspension geometry, I will be looking at that in detail soon but based on the set up the car came with the original size/pattern tyres are night and day better on these cars.
Quick Reply: [C2] 15x7 wheels on a stock C2?
