[C2] Fuse Box ACC Terminal
Old 07-24-2017, 10:00 PM
Sky65
Support Corvetteforum!
Sky65's Avatar
St. Jude Donor '05, '09, '15
Default Fuse Box ACC Terminal
Is terminal labeled ACC on the fuse panel accessory power? That is hot when key is on or in accessory position, off in off position?
Tom
Old 07-24-2017, 10:08 PM
65GGvert
65GGvert's Avatar
Received 3,220 Likes on 2,302 Posts
Please read my revised post after yours.
Old 07-24-2017, 10:10 PM
Sky65
Sky65's Avatar
Originally Posted by 65GGvert
Yes it is. Use a fuse in line with whatever you connect there.
Thanks!
Ah yes. Fuse it. I hadn't thought about that!
Tom
Old 07-24-2017, 10:21 PM
65GGvert
65GGvert's Avatar
Originally Posted by Sky65
Thanks!
Tom
You'd better measure voltage before you connect that. Looking at the back of the fuse box, it looks like that only has voltage when park or headlamps are on, and ignition doesn't matter. I was basing my answer on a modified block, check yours for 12v and you may have none when key is on. Sorry, but you need to verify what you have.
There is a bar that connects the green wire from the headlight switch to those two contacts, so it looks like it's "acc lamps" for both contacts and not "acc" on the left and "lamps" on the right one.
You may need to get your switched 12v from another source, like the radio plug or heater fan.
Sky65 (07-24-2017)
Old 07-24-2017, 10:29 PM
Sky65
Sky65's Avatar
Hmmmmm. Ok. I don't have a stock fuse panel in my car to test. I am looking for a switched power for a friends car. How about the Power Windows terminals?
Tom
Old 07-24-2017, 10:32 PM
buns
buns's Avatar
Acc Lps is short for accessory lamps. If the car had A/C, this is where you would connect your extra center dash illumination bulbs. Both terminals are connected. Power there only when lights are on.
The following 2 users liked this post by buns:
marshal135 (09-01-2021), Sky65 (07-24-2017)
Old 07-24-2017, 10:41 PM
Sky65
Sky65's Avatar
It looks like power windows terminals are battery power, not ignition switched?
Tom
Old 07-24-2017, 10:50 PM
65GGvert
65GGvert's Avatar
That's correct, the power window lugs are 12v constant.
Sky65 (07-24-2017)
Old 07-24-2017, 10:54 PM
Sky65
Sky65's Avatar
OK then. No open ign switched terminals on the fuse box. Any open switched terminals on the ign swt itself?
Tom
Old 07-24-2017, 10:56 PM
65GGvert
65GGvert's Avatar
If you MUST get power from the fuse box, that brown wire that connects to the left side (when installed) of the heater and radio fuses clips is switched before the fuses. You could tie in there and fuse the wire you're adding. An easier place would be the yellow wire in the radio connector ***'y. (or some have a black with yellow stripe). I don't know what you're adding, but it would go through the radio fuse in that case.
Sky65 (07-24-2017)
Old 07-24-2017, 10:59 PM
65GGvert
65GGvert's Avatar
Tom
The brown wire on the ignition switch connector is switched. It's the same electrical point shown at the fuse box with the blue circle on it in the picture I posted.
Old 07-24-2017, 11:02 PM
65GGvert
65GGvert's Avatar
Maybe if you identified what your connecting and where it will be mounted?
Old 07-25-2017, 11:01 AM
Sky65
Sky65's Avatar
Yes I should. Just looking for an ignition switched power to run LED DRL. I am looking for a plug it source if possible.
Tom
Old 07-25-2017, 02:34 PM
65GGvert
65GGvert's Avatar
You also have the brown wire to the wiper motor up there under the hood, but no open lugs to plug on to.
To Fuse Box ACC Terminal
Quick Reply: [C2] Fuse Box ACC Terminal
