square head plug
square head plug
sorry if this is a really dumb question but.......
I need to double check my oil pressure gauge in my dash against another gauge to make sure it's reading accurate or not.
JohnZ suggested I go out and purchase a mechanical oil pressure guage and plug it in where the square head plug is in the block just above the timing cover at around 11 o'clock.
I got the new mechanical oil pressure guage the other day but now i'm stuck.
I don't have the proper socket to remove the square-head plug. I know they make square headed sockets but I went to Sears to buy one and they said they don't carry them.
I was at my mechanics yesterday and he has the proper square-headed socket I need - it's a 9/32 size and he offered to lend it to me for 24 hours but I didn't feel it was right to take it and be responsible for his tools. I know it's not much but I feel funny taking another man's tools even for just a short time.
Since Sears doesn't carry this type of socket, can anyone recommend a place for me to try to get one. I'd rather drive and get one locally if possible rather than order one online somewhere. With very limited use on this socket I don't need to most top quality tool, just something to remove the plug and put it back afterwards so even if it was something like a discount brand store tool it would most likely be fine for now.
Originally Posted by Brutal64
Do you guys have Tool Zone stores out there. They would probably have it. If not have you tried a 1/4" drive socket extension.
No ,no tool zone stores
i don't have a 1/4" extention, only a 3/8" and 1/2" extention.
would a 1/4" extention be off-sized too much to worry about rounding off the corners?
Try NAPA
Do you have a NAPA auto parts store nearby? They may be able to help you.
You might also check for a tool distributor, such as S-K or Snap-On.
Barry - I take it your intake plug is a depressed square hole, as opposed to a raised square plug? The latter is "correct", fyi, although the former is certainly found in use.
If it is a raised square a crescent wrench will, of course, work - it is a 1/2", if I am not mistaken.
If it a raised square, you should be able to use the female end of the extension over the plug and grab the male end of the extension with a crescent wrench or (gasp) a locking pliers a.k.a. Vice Grip.
Brian
Brian
yes, there is a NAPA not too far away.
Didn't think of them. I know they sell parts, but i didn't know they have tools too.
I'll give them a try.
Thanks!
Thanks!
it is a raised square plug.
there really isn't enough room to get a cresent wrench in there and still turn it and to honest I hate the idea of "trying to make it work" with the wrong tools. I'm afriad of rounding off the corners if i do that than i'm really screwed - no pun intended!
I'll try NAPA. if they don't have it I guess i'll have to call my mechanic and get the number of the snap-on tool guy.
damn, i hate the idea of doing that as I'll be way too tempted to start buying a lot of really nice tools from him!
LOL
Snap-On has what you are looking for. Be very careful when you go after this plug. If it's been in there since day one it will be a bitch to get out.
Have a look at the part of the block where the oil filter mount is, sometimes there is a plug there that can be removed. If this was a rat they have plugs all over the place.
Originally Posted by BarryK
CT
CT
LOL
LOL
A local wrecking yard yielded those plugs, gratis. IIRC I think I used a 7/16's 12-point socket on that square plug ..
John
ahh grasshoper, as I suspected. To be honest, I think a properly-sized crescent wrench is the "right" tool for square plugs, but Check out Brian's advice, if it is a 1/2" AND you have a 1/2" drive set around, flipping a 1/2" socket extension bar around will essentially give you the best possible tool to put on the plug - you just then need to figure out a way to turn THAT - I still vote for a 1/2" crescent wrench laid on the extension bar's square end. However, as all others have pointed out, and I can tell you from experience, these buggers sometimes weld themselves to the manifold, although that mostly happens in coolant-exposed locations, like someone blocking off the SHP waterpump bypass with a plug. Point being if it ain't coming off without having to put one or both of your feet on the manifold for leverage, try another path.
Received 1,843 Likes
I think you can find the socket at a plumbing supply house.
I think you can find the socket at a plumbing supply house. Do not use anything on it but a four point square socket.
If you don't care about the paint on the front of your engine, a little heat around the plug will go a long way on a stuck plug. I've removed a few. Never had any problem.
I agree, I really don't want to use anything other than a 4 point socket. I wouldn't have thought about a plumbing supply place but i'll try that also.
The heat idea is good but i DO care about the paint on my motor so I guess that's out
thanks!
if it's a 1/2" a 1/2" extension handle "female" end is pretty much the same exact thing as a "4 point" socket. But if a proper socket head can be readily found at a plumbing supply house (makes perfect sense to me too) I would go put my $5 down and get it myself.
I do agree that I would not use an 12 point socket on it (I really don't use those too much on regular hexagonal nuts, I tend to stick with 6 point sockets) as the chances of rounding off the corners are pretty high
Received 1,126 Likes
SK tools also has these special sockets. If you can't find one I will get the part number for you in SK.
