C1 & C2 Parts C1 & C2 Corvette Performance Parts, Rare NOS and NLA Chevy Parts, Wheels & Tires, Exterior Enhancements, Aftermarket
327 Engine with Roller Cam, Edelbrock heads,
Old 10-25-2010, 02:49 PM
Corbrastang
Corbrastang's Avatar
Default 327 Engine with Roller Cam, Edelbrock heads,
Over 6,500 invested
Asking-4,200
I am pulling the replacement 327 engine out of my 65 and putting the original engine back in.
This engine only has 800 miles on it since it was professionally built by proline race engines in woodstock, georgia. The full rotating assembly was balanced correctly using mallory. I installed the cylinder heads.
-Edelbrock Performer RPM aluminum heads with Springs to match hyraulic roller cam
-Comp Cams Retro-fit Hydraulic roller lifters
-Comp Cams hydraulic roller camshaft-12-423-8
Specs: Duration 224/230 Lift: .502/.510 Lobe Seperation 110
-Compatible gear for stock distributor
-Keith Black Hypereutectic Pistons 10.1:1 compression with the 64cc heads
-Lightweight Eagle Rods with ARP bolts
-Hardened Pushrods
-ARP Head bolts
-Crane Gold Full Roller Rockers with low profile locks-CLEARS stock Aluminum Valve Covers
-Comes with Clutch and lightweight steel flywheel
Block was bored .030 over Date is June of 65 870 block
Does not come with intake, carb, waterpump, oil pan, or timing cover. I need these items for the original block.
This is a great motor with lots of power. I have just over 6,500 invested in the engine
Asking 4,200
. Please let me know if you are interested.
It runs great and has tons of power throughout the rpm range. The motor has not been ragged out and i will guarantee that it will run great. I did some spirited driving in the car, but nothing that would jeopardize the engine. It has not seen over 6,000 rpm and has only seen 5800 about 5 times. The video below being one of them.
I'm just putting my car back to stock
Pics of engine before cylinder heads were installed
Light acceleration and then cruising at about 45mph
Hard acceleration 1st to 4th
Old 10-25-2010, 04:10 PM
Corbrastang
Couple more videos
Running in driveway
Old 10-25-2010, 04:35 PM
Corbrastang
Video of engine being turned on and off multiple times. I have never had an older car start like this-it must be the roller camshaft. it even starts this quickly when cold.
Old 10-25-2010, 05:26 PM
Corbrastang
And last one of some slight spirited driving from 35mph to 80mph
Old 10-25-2010, 10:14 PM
robert miller
robert miller's Avatar
Received 1,762 Likes on 1,529 Posts
Default ttt
Nice looking car man love the color also.
Old 10-25-2010, 10:42 PM
Corbrastang
Thanks! Want to buy it?
Unfortunately some bubbles have come up on the left fender, car was painted about 2 years ago, and it needs a new top. Hopefully somebody will want the engine and it will fund the repairs.
Old 10-26-2010, 07:53 PM
woodsdesign
woodsdesign's Avatar
Have you had it dynoed? Any idea of the HP. Where are you located/
Larry
Old 10-26-2010, 10:04 PM
robert miller
P.M. to you man...
To 327 Engine with Roller Cam, Edelbrock heads,
Quick Reply: 327 Engine with Roller Cam, Edelbrock heads,
